Filled up fuel now won't start -Detroit diesel 60 series
Discussion in 'Kenworth Forum' started by Airman89, Sep 26, 2016.
  1. Airman89
    Airman89 Light Load Member
    148
    15
    Jul 8, 2015
    Any thoughts? It will crank and crank but won't fire. First time it's started and sputtered but shut right off. Now there's no sign of firing up
  3. ibcalm19
    ibcalm19 Road Train Member
    1,399
    2,280
    Nov 30, 2015
    Pennsylvania
    How low were you fuel when you filled up? Did you give her a shot of ether to try & fire her up?
    Airman89 Thanks this.
  4. Airman89
    148
    15
    Jul 8, 2015
    Yeah I gave her a shot and she revved up to 1200 rpms twice then died out. I was on about an 1/8th tank. I have two 150 gallon tanks.
  5. ibcalm19
    1,399
    2,280
    Nov 30, 2015
    Pennsylvania
    It might be a possibility you lost prime & got air in the line. Is someone helping you or doing it by yourself?
  6. Airman89
    148
    15
    Jul 8, 2015
  7. ibcalm19
    1,399
    2,280
    Nov 30, 2015
    Pennsylvania
    It would help to have another person spraying the ether while your starting the truck (trying to get her primed. Nobody around to help?
  8. Bakerman
    Bakerman Road Train Member
    4,661
    8,796
    Jan 27, 2013
    Phoenix, AZ
    Sounds like you were cutting it a little too close. Like @ibcalm19 says, spray some ether and try to get it going.
    Be careful with that ether, it's like crack to a diesel engine.
    Bean Jr., Dye Guardian and Airman89 Thank this.
  9. ibcalm19
    1,399
    2,280
    Nov 30, 2015
    Pennsylvania
    True indeed @Bakerman try definitely not using on my caterpillar
    Airman89 and Bakerman Thank this.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,632
    Feb 6, 2016
    Do detroits have had primer pumps or electric prime pumps???
  11. Hulld
    Hulld Road Train Member
    2,882
    6,557
    Oct 19, 2015
    Upstate NY
    Does it have a Davco water separate filter on the frame?
  • Draft saved Draft deleted
