Freightliner 114SD - Reduced power at 9 Pin Diagnostic Connector
Discussion in 'Freightliner Forum' started by Taurus, Dec 7, 2019.
  1. Taurus
    Taurus Bobtail Member
    Have Can Bus error U0073 In checking resistance and voltage at 9 Pin diagnostic connector the first problem that appears is I only have 3.6V at PIN B instead of 12V. This is EOKO voltage but cannot find a wiring diagram to see where Pin B is fed from. A blown fuse or other open would have zero volts. Has anyone seen this before?
  2. mhyn
    mhyn Road Train Member
    4,135
    4,111
    Dec 29, 2008
    Northridge, CA
    yeah men... could be bad gateway....
  • Draft saved Draft deleted
