Frieghtliner m2 106 indicator light???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trask97140, Aug 31, 2019.
  1. Trask97140
    Trask97140 Bobtail Member
    Had this light come, dont recall it being on in the past. Turns on when I put it into drive. Looks like it might be associated with cruise control but I've messed with buttons and doesn't turn the indicator on or off. I cant find it in the manual anywhere... Some insight would be greatly appreciated.
    Thanks,
    Trask
  2. Working2party
    Working2party Medium Load Member
    569
    642
    Feb 10, 2018
    Kansas
    Looks like cruise control active light. Should go off if you turn the cruise switch off. If it isn’t then it could be a PTO sense wire is grounded. I’m not familiar enough with the M2 to be able to tell you where to start looking.
  3. Fmlfrtho
    Fmlfrtho Bobtail Member
    31
    12
    Mar 5, 2019
    Cruise control on the m2 is usually a toggle switch located left of the steering wheel, the one without the paddle
  • Draft saved Draft deleted
