so I just had my shop replace all the brake shoes on the truck. One guy did it by hisself And of course I feel like it was to much work for him but now when I brake between 40-50mph I have a wobble in the steering until I apply harder pressure. Everything was fine before we replaced the pads so what would be the cause of this?
Front end wobble under brakes at 40mph, new shoes
Discussion in 'International Forum' started by Twista89, Sep 21, 2018.
Disc or drum brakes?
Drums
Warped drum ?
Loose shoe ?
Poor brake stroke alignment causing uneven application?x1Heavy and stillwurkin Thank this. -
Did he have the hubs off? If so I'd check your wheel bearing play.
stillwurkin Thanks this. -
You have a drum likely not sitting perfectly centered on the hub.
x1Heavy Thanks this. -
Yea that’s what I figured when he mentioned the tabs. I looked at them and they weren’t centered but I replace the drums anyway. It’s a lot better but I still get a small one at 35mph now.
Heavyd Thanks this.
