Fuel cards and discounts
Discussion in 'Canadian Truckers Forum' started by MSQUARED, Apr 25, 2022.
  1. MSQUARED
    MSQUARED Light Load Member
    271
    354
    Mar 28, 2021
    With fuel prices through the roof just wanted to see what people are using for fuel cards and who has the better discounts
    BVD card has decent discounts but the problem is only good at Love's in the USA and Petropass in Canada.
  3. Sygmadriver03
    Sygmadriver03 Bobtail Member
    48
    34
    May 11, 2016
    Looks like ppl don't use fuel cards or won't share there secrets. I use kwik fill card. .08 off a gallon. Downside only in pa & ny. Im local so works for me but next spring hitting otr & looking for better card to use.
  4. Judge
    40,581
    Newport, Ar
    mudflap app.
    Motive(Formerly Keeptruckin) fuel card last 2-3 weeks. .21 off loves .20 Js/pilots .05 everywhere else.
    plus you can add it into mudflap app.
    so far you get mudflap savings, then when KT bills they give additional .05
  5. God prefers Diesels
    3,613
    18,018
    Jun 26, 2020
    South Texas
    Say fuel is $5.00, and Mudflap drops it to $4.50. Does KT give even more discount on top of that? Could you explain more about it?
  6. Judge
    40,581
    Newport, Ar
    they did mine last week.
    was 5.10, mudflap was 4.51.
    mudflap receipt showed 4.51 price then when they auto withdrawaled they gave additional .05 saving another $13.65 on top of the $85.60 mudflap saved.
  7. bad-luck
    bad-luck Road Train Member
    2,345
    3,863
    Nov 16, 2013
    Baltimore, Maryland
    What areas do you run? I run primarily the east coast and have nastc. Nastc seems to give the best discounts for the area that I run.
  8. MSQUARED
    271
    354
    Mar 28, 2021
    What about AtoB fuel cards? Seem to be advertising alot lateky
  9. Judge
    40,581
    Newport, Ar
    I run South and Midwest far east as i go is the carolinas.
    North be SD, i’ll do GA but avoid FL, done it if it’s got enough to make it worth while.
    West is Texas north to SD and all between
  • Draft saved Draft deleted
