Hello I have a 2007 Volvo d12 and in feb I put a new fuel pump and just last week I’m getting a code comeing up saying fuel feed pressure mechanical fault mid 128 sid 94 fmi 7 I just changed the oil filters and fuel filters and still showing same code and now when I turn it off I have to prime it 3 to 4 times to start it up any ideas please would be helpful
Fuel feed pressure Volvo d12
Discussion in 'Volvo Forum' started by Tommy2019, Aug 5, 2019.
Could be injectors cups check valves, fuel filter housing very common or maybe accessory drive is messed up how was the shaft in the old pump that u pulled out.
sipnjoos Thanks this. -
Like nasriza said its most likely accesorie drive or filter housing. If its filter housing change it before winter it gets worse when its cold don't ask me how i know
If the shaft on the old pump was worn out than I would consider changing accessory drive I always change them as a set start with filter housing they are known to make a lot of problems as well
Thank you I will try the filter housing today
I changed the filter housing Tuesday and went to work yesterday maybe 50 miles in the code came back up check fuel filter and fuel feed pressure so same code again at least I didn’t have to prime it anymore when starting but I think next step is the accessory drive change
Before you change the accessory drive, try the fuel pressure relief valve. It may be stuck open or the spring is weak if it's original. It's at the front of the head on the driver's side next to the valve cover emissions sticker. There's a banjo bolt with a fuel line screwed into the head and the valve screws into the top of the banjo bolt. For around $30 and 3 minutes, it's easier than going straight for the accessory drive. The part number is 21697342.
QUALITYTRUCK and Tommy2019 Thank this. -
Thank you I will defiantly look into that and will try it first
I changed fuel pump, fuel filter housing and accessory drive in march and i got same code again month ago, first once a week and later every day. I changed fuel return valve and everything is fine now. Part is $55
