FUEL HELP better fuel mileage
Discussion in 'Freightliner Forum' started by GHOST1911, Jul 28, 2026.
  1. GHOST1911
    GHOST1911 Bobtail Member
    5
    Jun 27, 2026
    I have a 2004 classic xl 525 cat twin turbo
    Looking for information on how to get better fuel mileage.
    Thank you in advance
  3. Big Road Skateboard
    7,698
    44,592
    May 2, 2021
    You could
    : Drive faster
    : Drive slower
    :Fix boost leaks
    :Turn off the fan
    :Turn off the A/C
    :Remove the trailer
    :Regear it
    :Better tires
    :New Injectors
    :Overhaul it
    :Stop Driving
    : Don't use the high side of trans
    Yeah, Vague questions deserve vague answers
    86scotty, mtoo, cke and 10 others Thank this.
  4. 062
    062 Road Train Member
    6,410
    34,272
    Oct 20, 2013
    Buy a Volvo.
    86scotty, mtoo, Diesel Dave and 2 others Thank this.
  5. IH Truck Guy
    5,200
    60,737
    Mar 2, 2008
    Purgatory
    Just put less fuel in it.
    cke, Ddh77777, Stay Puft and 2 others Thank this.
  6. drh72
    drh72 Light Load Member
    182
    310
    Aug 19, 2012
    Northeast Minnesota
    What are you getting for fuel mileage now? The easiest way that doesn't cost money is to try progressive shifting (if you are not already). Use the terrain to your advantage, check tire pressures often and slow down.
    Concorde Thanks this.
  7. bad-luck
    bad-luck Road Train Member
    3,517
    6,519
    Nov 16, 2013
    Baltimore, Maryland
    Is your engine an MBN motor?
  8. Concorde
    Concorde Road Train Member
    5,842
    20,866
    Jun 29, 2016
    West Melbourne Florida
    Charge more and don’t worry about mpg :)
  9. Big Road Skateboard
    7,698
    44,592
    May 2, 2021
    That's what I do, but that ain't enough.
    cke and Concorde Thank this.
  10. Concorde
    5,842
    20,866
    Jun 29, 2016
    Lol, it’s never enough!
    Leaving El Paso today heading to Florida..thinking to take I-20 then drop back down to 10 via I-49. Found cheaper fuel on that route and I don’t have to deal with all the construction, San Antonio and Houston.
    Done this load many times and looking for a change of scenery…still debating.
  11. bryan21384
    bryan21384 Road Train Member
    16,219
    35,532
    Sep 18, 2009
    Memphis, TN
    Go no faster than 65. Make sure you have even weight distribution on your trailer. Keep your truck and motor as clean as possible. Use your cruise control as often as possible. Stay on top of your maintenance.
