Fuel pump bad, fuel module showing metal
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, Jul 8, 2020.
  1. mitmaks
    mitmaks Road Train Member
    2,450
    1,952
    May 16, 2014
    That's if you dont upgrade fuel pump plungers
    Midwest Trucker and Dave_in_AZ Thank this.
  3. Dave_in_AZ
    315,710
    Yea i changed my ceramic ones to metal at 700K.
    $300
    Midwest Trucker Thanks this.
  4. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    Mine happen same thing at 350,000miles.
    Check engine light came goung uphill with low fuel rail pressure. Went to dealer . Found metal shavings at fuel filter screen. Replace fuel filter module, fuel lines, fuel pump, cleaned fuel tanks. Total bill $9400
  5. RunningAces
    RunningAces Road Train Member
    1,183
    2,386
    Jul 2, 2017
    My isx15 was manufactured in 2016, it's in a 2017 t680. How do I know if my fuel pump has the ceramic plungers or newer titanium?
    I have 450k on the truck, should I replace or rebuild the fuel pump as PM?
  6. Midwest Trucker
    5,771
    20,598
    Aug 31, 2018
    Give your engines serial number to Cummins and ask about it. It’s probably updated I’d I had to guess as around that time my isx was getting the update. I’d check to be sure though.
    RunningAces Thanks this.
  7. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    277
    Nov 24, 2019
    Some would say to replace the guts in your fuel pump as preventative maintenance. Regardless of what year it is.
  8. RunningAces
    1,183
    2,386
    Jul 2, 2017
    Who do you take it to for that to be done?
  9. Mattmanstroked
    185
    277
    Nov 24, 2019
    Running aces, I did mine myself.
