Canadian fuel is the easiest way to avoid gelling. They come premixed with antigel products.
You can also blend #1 and #2 (1:3 ratio, 50 to 150 gals).
Or, you can use antigel additives for #2. Like Power Service in the white bottle or Howe's Diesel Treat.
My company uses the Power Service products. One small bottle of white for every 100 gals of #2 (essentially one bottle every full from half tanks) and if the temps go below -35°C (which they do in Canada regularly), use the white as normal, and throw in a quarter bottle of 911. When coming back into Canada, we try to fill as quickly as possible with Canadian fuel.
911 is essentially hyper-concentrate of the antigel, generally only used to reverse gelling, and will make your fuel burn much faster, but when its -45°C before the windchill, you can't afford to have fuel gel on you. You'll die.
Fuel treatment for extremely low temps.
Discussion in 'Canadian Truckers Forum' started by Hotpat, Feb 8, 2019.
Page 3 of 5
fss99701, HighwaySuperTramp and mudflap77 Thank this.
No the engine will. I'll burn the truck before I freeze to death. LolSummitteer, Hammer166 and Zeviander Thank this. -
Why do I see a lot of Volvo trucks gel up northern ontario and western Canada. Is it that they are not returning enough fuel from the engine to the tank.
Phantom Trucker and Hammer166 Thank this.
mudflap77 Thanks this.
"This is rock bottom."
Lolmudflap77 Thanks this. -
Zeviander Thanks this.
Page 3 of 5
