Gauge cluster won’t turn on, please help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 09DD60, Oct 24, 2021.
  1. 09DD60
    09DD60 Bobtail Member
    17
    Jun 7, 2021
    2014 cxu613.
    I installed a tarp switch in my truck for dump, and now my gauge cluster won’t work. Won’t turn on at all, won’t sweep. The screen lights up but it is blank, and 4 random lights are blinking in top corner (right turn signal, R, N) Will try replacing my batteries and cleaning grounds today. Any ideas??
  3. buddyd157
    buddyd157 Road Train Member
    11,084
    25,634
    May 25, 2017
    under a shade tree
    remove that recently installed switch, and see itf it all works again, and make sure too, to check all fuses and relays/circuit breakers.
  4. 09DD60
    17
    Jun 7, 2021
    Yea I tried removing the switch and it’s still doing the same thing. It comes with its own circuit breaker so I’m assuming I didn’t short anything.
    seems like it’s just the gauge cluster effected. Radio/ head lights etc still work. Truck still starts.
  5. buddyd157
    11,084
    25,634
    May 25, 2017
    under a shade tree
    if everything worked, BEFORE you installed that switch, and now it doesn't...??
    you shorted something out. so you cannot assume you didn't do anything wrong.
    you hot wired it into something you shouldn't have, maybe..?????
  6. 09DD60
    17
    Jun 7, 2021
    Definitely possible. I was thinking perhaps one of the grounds isn’t getting a good connection anymore or something of the sort. Or maybe the battery is weak? They’re older batteries. Just trying to think of the easy stuff first
  7. buddyd157
    11,084
    25,634
    May 25, 2017
    under a shade tree
    kinda coincidental the grounds went bad, after you wired it up, but they were ok, before you wired it up.
    if you never touched the ground wires to begin with, then i'd surmise you shorted something out.
    good luck, i have nothing else.
    Ross_Tech Thanks this.
  • Draft saved Draft deleted
