Got a oil leak. 2012 cascadia dd15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by reelheavy, May 29, 2020.
  1. reelheavy
    reelheavy Light Load Member
    53
    26
    Mar 15, 2017
    Maryland
    I noticed a leak on one of my trucks. While moving some trailers. While the motor was running I left a small drop smaller that a dime then I look under it and seen some gunk look like some blow by. Pics attached. I took the pictures from the drivers side right behind the front wheel. Gonna see what I can see in the morning. Any ideas? Or things to look for in diagnosing the problem? All help greatly appreciated. 20200529_222202.jpg 20200529_222240.jpg 20200529_222202.jpg 20200529_222202.jpg 20200529_222240.jpg
    truckdriver31 Thanks this.
    Trucking Jobs in 30 seconds
  3. truckdriver31
    5,126
    5,568
    Sep 18, 2013
    clean it with brake cleaner good around oil pan. walmart sales break cleaner in the can cheap
    PE_T Thanks this.
  4. ast26909
    ast26909 Medium Load Member
    395
    254
    Mar 1, 2018
    It's probably the cam housing gasket or the valve cover gasket.
  5. PE_T
    PE_T Road Train Member
    Yeah, you’re going to have to clean the engine a bit to get a better look. It can be the air compressor or the fuel pump.
  6. Motto
    Motto Light Load Member
    102
    120
    Apr 10, 2020
    If its not coming out from top then you need to change o rings of air compressor and fuel pump. This usually happens around 800k miles. If its coming from top then could be cam housing gasket or valve cover gasket .
  • Draft saved Draft deleted
