GPS Could Save Trucking Industry $53 Billion
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Cybergal, Jul 1, 2008.
  1. Cybergal
    Cybergal Road Train Member
    6,272
    2,399
    Oct 20, 2008
    7/1/08
    panhandlepat and Baack Thank this.
  3. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    PHFFFFPS, RAND MCNALLY NEVER STEERED ME WRONG! ALTHOUGH "NEWSCHOOL" I'LL STICK TO "OLDSHCOOL":biggrin_25513:
  4. RAG
    RAG R.I.P.
    541
    4,922
    Nov 23, 2007
    Tonga
    This just aint true.
    I have tested both the world nav and the copilot unit (beta test) They just dont work in the real world.:biggrin_25510:
    I sure would buy one if it did work
  5. Truckerjo
    Truckerjo Road Train Member
    2,314
    341
    Sep 5, 2006
    Indiana
    Hum? you sure it was not the operator that was not working properly? :biggrin_255:
    I used Co-Pilot and had no real issues but I read the directions and also didn't rely 100% on its routing (as it says in the instructions) Used properly it is a great "tool" to have but you still need to use old school common sense along with it, that means double check by calling shipper receiver and get cross roads ext... then verify if the program is routing you correctly.... And most important YOU STILL NEED TO FOLLOW LOCAL TRUCK ROUTES, this means once you leave the Interstate your on your own far as local restrictions go (except low bridges that copilot pretty much is 99.99999% on)
    One thing that people should do and most have no clue is share your routing with the manufacture.. Almost every program has a way to upload routes/addresses that you went to, this way they can update locations if it was wrong.. Co-pilot (if your online) will detect that you have went to a new area that has not been mapped (new construction for example), a window will pop up and ask you if it is okay to share that information with them so they can update their program... The more people who start doing this the better the programs become........
  6. Nick352
    Nick352 Light Load Member
    82
    24
    Jun 19, 2008
    Neosho, Mo.
    GPS will take some time to be near error free. We had the same issues in aviation. VOR, NDB, LORAN, and now GPS. It's getting much better, but with all new things, it takes time to get all of the updates done.
    I completely agree with TruckerJo on the updates. Best way to get the system up to speed in the shortest time.
    Semper-Fi
    Nick
    Truckerjo Thanks this.
