had low def, engine was at derate, dealership told me that 4 out of 6 cylinders are not giving enoug
Discussion in 'Questions From New Drivers' started by tanveer702, Feb 1, 2019.
  1. TaterFox
    TaterFox Medium Load Member
    331
    422
    Dec 19, 2017
    Ashland City, TN
    I had the similar code on my Shaker back at pumpkin. Clogged def filter.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    SPN 605 says refridgerant high pressure switch. Your a/c .
    TaterFox Thanks this.
  4. Brandt
    Brandt Road Train Member
    4,495
    6,146
    Sep 17, 2012
    If the DEF yellow light is something is wrong with the DEF system. Not the square light. Their is a yellow round light. Just like the low fuel light but is means something is wrong with the DEF system. You can fill the DEF tank and the round yellow light will stay on.
    Once that round light come on you can only drive like 500 miles, then you get the 25% derate and limit to 55MPH or something like that.
  5. AModelCat
    158,460
    As stated above by other posters, what tests were performed to come to the conclusion that 4/6 cylinders are not up to snuff?
  6. SoCalRed
    SoCalRed Medium Load Member
    437
    851
    Feb 7, 2017
    CA
    Don’t be upset with people cracking a joke.
    If you need advice you really have to go into some details.
    What does it mean 4 cylinders not giving enough power? Low compression? Incomplete combustion? How did the dealer determined that?
    otherhalftw and AModelCat Thank this.
  7. MACK E-6
    48,744
    225,130
    Relax. He just likes pointing out typos.
    otherhalftw and buddyd157 Thank this.
