Hard break pedal
Discussion in 'Questions To Truckers From The General Public' started by Marcus P, Apr 8, 2020.
  1. Marcus P
    Marcus P Bobtail Member
    I have a 1998 international 9200 and I let it sit for a few months and now my break pedal is extremely hard. I can't press them at all. Is there anything I could do to avoid spending money at a shop or should I take it to a shop to get fixed?
  3. 062
    062 Road Train Member
    6,252
    33,662
    Oct 20, 2013
    It’s most likely the plunger in the foot valve is seized up. You can try pb blaster or similar to free it up. I wouldn’t trust it unless it breaks loose easily. Depending on how it’s mounted they can be a pain to replace.
    @Heavyd @spsauerland @pushbroom may have some other ideas.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,140
    Mar 5, 2016
    White County, Arkansas
    Those older brake pedals are fairly common. Should not be too difficult to free up or replace at shop.
    Its really important to have it working right. Lives depend on it without saying.
  5. Heavyd
    Heavyd Road Train Member
    7,801
    6,247
    Feb 4, 2009
    Spray with a good penetrant. Work it in by trying to move it up and down over and over and hopefully it frees up.
    062 Thanks this.
  6. AModelCat
    161,208
    Myself I'd just change the treadle valve. If the rubber seals are hard enough to cause the plunger to stick its probably on its last legs anyways.
    To me, brakes are one of the most important things on a vehicle. I wouldn't skimp on them.
    Cowboyrich and 062 Thank this.
