Hauling equipment South to North.
Discussion in 'Questions From New Drivers' started by James j, Feb 8, 2020.
  1. James j
    James j Light Load Member
    63
    72
    Oct 31, 2019
    San diego
    As I was lighting my pilot light on my heater for the first time this year in San Diego.I got to thinking about the drivers who haul equipment.Do you have to put antigel in the equipment tanks?I would think it would suck to have something gel up and not be able to drive it off the trailer.Thanks
    Dave_in_AZ and Cabinover101 Thank this.
  3. James j
    63
    72
    Oct 31, 2019
    San diego
    Hauling it South to North
    Cabinover101 Thanks this.
  4. clausland
    clausland Road Train Member
    1,933
    11,066
    Dec 5, 2014
    North Woods
    If it runs on diesel, and you fuel up down south, and then come up here in the winter, yeah, you better add anti-gel to it before you leave. Make sure you run too and ensure it gets into the filter and pump etc....
    Dave_in_AZ, snowwy and D.Tibbitt Thank this.
  5. xsetra
    xsetra Road Train Member
    4,928
    6,588
    Aug 21, 2011
    Treat fuel or have other equipment on site to pull it off transport trailer.
    D.Tibbitt Thanks this.
  6. Deere hunter
    1,274
    3,873
    Aug 5, 2017
    Shallowater Texas
    We’ve hauled equipment from Houston area to Iowa , Minnesota ,Wisconsin and up in that area in the winter time and if it gets around freezing we start it and let it run then when you get there you just drive it off!
  7. JolliRoger
    84,534
    Used southern equipment brings a premium up north. Different weather elements expose tires,
    hoses, other expendables exposed to extreme temps. Rust is rampant on dealers used lots.
  8. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,165
    Jul 28, 2019
    One year I loaded a John Deere tractor in South Florida and took it up to KY that year happened to be close to 0-10 degrees. The Buyer asked me to check the freeze point on the coolant it was ok. When I got up there they had to use like 3 sets of jumper cables and pickup trucks to get the thing started. Of course it probably didn't have the best battery in it either.
    Dave_in_AZ and x1Heavy Thank this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,104
    Mar 5, 2016
    White County, Arkansas
    In winter we run. Engine idles constantly when not running. Fuel return lines to the tanks take care of that.
    However if you have equipment with it's own fuel and not running going north? You need to put in anti gel or be prepared to run it a little when freezing or below.
    Deere hunter Thanks this.
  10. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,484
    Apr 24, 2011
    LA (lower Alabama)
    I always call the dealer ahead of time and ask them what they want me to do. Sometimes they don’t want me messing with it for whatever reason. It’s usually new stuff and they say they’ll figure it out once I get there
  11. HoneyBadger67
    2,056
    4,509
    Dec 15, 2018
    Savannah, TN
    New equipment picked up at the port or assembly plant usually doesn't have a lot of fuel in it. Sometimes I'll add fuel and let it run for the day as I'm driving into the colder weather, (if it's an 'inexpensive' piece), high dollar pieces I just let them deal with when I get there. I figure waiting an hour for them to get it started is cheaper than me adding the wrong supplement and screwing something up.
