HEAD LIGHT PROBLEM
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRS1955, Dec 3, 2019 at 5:31 AM.
  1. BRS1955
    BRS1955 Bobtail Member
    37
    19
    Nov 16, 2016
    Kentucky
    right head light on 2007 379 pete goes off sometimes and is at the point where it is off more then it is on. I am thinking maybe a ground problem. does anyone know where it would be grounded. 3 prong connection.
  2. FreightyAK
    FreightyAK Bobtail Member
    25
    20
    Aug 7, 2018
    AK
    Check the wires from the harness plug foward to the light. Also check the wires that cross over from the driverside. Its common to find a bad wire there.
  3. RocketScott
    RocketScott Light Load Member
    193
    82
    Apr 10, 2013
    Tacoma, WA
    Check by the hinges too. The wires can get pinched there
    I believe the headlights ground all the way back inside the cab. If you have a multi tester you can check voltage and ground on the harness behind the bumper and at the firewall
  • Draft saved Draft deleted
