Hello! A quick question?????
Discussion in 'Questions From New Drivers' started by txbigdaddy, Jun 1, 2013.
  1. txbigdaddy
    txbigdaddy Bobtail Member
    34
    9
    May 17, 2013
    Ok i have been driving for the last 11 years all around southeast texas and soutwest louisiana but next week I start a new job and ive never drove in the mountains or even snow more than a foot deep"being southeast texas born and bread lol" so any advice y'all have would be great thanks
    critters Thanks this.
  3. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    Slow and easy,a little common sense will go a long ways, you'll be fine.
    Tonythetruckerdude and txbigdaddy Thank this.
  4. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    For mountains, make sure you select the right gear on down hills and use your Jake. When you brake you should not brake for more then 3 seconds at a time. Braking longer or riding the brake will result in brake fade. Also keep an eye on you air. If your using up your air to quick, brake harder and longer and try to lengthen the time in between braking. If you choose the right gear you wont have any trouble. Weight of the load aerodynamic of the truck and steepness of the grade are the main factors for choosing a gear.
    Criminey Jade and txbigdaddy Thank this.
  5. okiedokie
    okiedokie Road Train Member
    12,390
    92,842
    Jun 13, 2011
    PNWET
    You might want to come off the first few times w/ all jake and some brakes. Let the engine do the work. Gear selection is vitial. Hit the 4 ways if your under 25mph and Run it cool. It's alot easier to speed up than slow down.
    txbigdaddy and Criminey Jade Thank this.
  6. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,977
    Apr 19, 2011
    Whatever you do, never use your jakes on snow/ice.
  7. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Thats exactly how I felt when I started driving trk with big cities.Why don't you see if you can go on a couple runs with a driver so you can get a feel of what you'll have to do solo.
    txbigdaddy Thanks this.
  8. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I know that what DOT recommends, but it is BS, i use mine on snow all the time with no problems. Think about it, Jack knifes primarily happen when the trailer wheels lock up. Trailer wheels wont lock with jake. Theoreticaly the trailer could swing around if the cab slowed fast enough, but highly unlikely since the jake doesn't slow it that fast. If you use your brakes your far more likely to cause an 18 wheel skid when apply braking to all axles. With a Jake your only slowing down 2 axles, not braking any of them. (assuming you have your power divider on which I would in snow) You wont lock up those axles and the slow down is not that intense. I keep an eye on my trailer and if it gets out of line ill turn off jake, but i have never had it happen.
    I've taken 7%+ grades in snow and had no problem. I just kept it slow and used my jake to control speed. Proper use of Jake is to maintain speed not really slow down the truck.
    txbigdaddy and biged169 Thank this.
  9. Big_jon
    Big_jon Light Load Member
    139
    60
    Apr 12, 2013
    I agree except for the part about the jackknife. If the trailer brakes lock nothing happens, you stay in a straight line. I think you got a sentance structure problem?
  10. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    Actually a tire that is not turning has NO traction at all and may cause a jack knife situation. Here is an article you may want to read;
    http://ezinearticles.com/?Tips-to-Avoid-Jackknife-Accidents&id=5292599
    http://auto.howstuffworks.com/auto-...towing/maneuvers/how-to-avoid-jackknifing.htm
  11. Scooter Jones
    9,551
    19,977
    Apr 19, 2011
    Can you provide me links to any of the common retarder brake manufacturers where they advise it's okay to use them on snow/ice???
