*HELP* 06 Freightliner Columbia feels to be hopping
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Truckin2Eat, Jun 22, 2017.
  1. Truckin2Eat
    Truckin2Eat Medium Load Member
    305
    86
    Jul 2, 2013
    GA
    I'm at the point where im frustrated. My 06 Columbia is bouncing/hopping. Seems to be coming from the rear. I have had the front end jacked up to have it inspected my mechanic said he doesn't see anything wrong there. A guy told me his truck was doing the same thing he replace the rear shocks and it solved the problem. Well I replaced my rear shocks and I still have the same issue. My steer tires are brand new and one guy said to check my rear tires i mean my rear tires are not brand new but they pass inspection. But i had them checked anyway my tire man jack both axles up and said they are fine.Best way I can describe what the feelings is the way a car rides when one of the tires have a knot in then. If anyone could help me out I would appreciate it.
  3. boneebone
    boneebone Road Train Member
    2,233
    2,268
    Mar 13, 2009
    It could be a out of round tire or a tire with a bad belt that's sticking up slightly.
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,468
    Nov 7, 2007
    Possum Booger, Alabama
    First, jack it up and check the tires for out of round. If they are out and have enough tread left, shave them to make them run true again.
    Then check your driveshaft slip joints. If they are siezed, it will cause the rear ends to bind when trying to move up and down.
  5. ebill45
    ebill45 Light Load Member
    167
    105
    Oct 11, 2011
    dalton ga
    Mine was the aluminum hubs on the back warped. I don't know if they still put those hubs on freightliners. Mine was 2001. Easy way to check drums, tires , wheels hubs is to jack the drive axles off the ground and run the back so you can see the wheels turning.
  6. ebill45
    167
    105
    Oct 11, 2011
    dalton ga
    Also the slip yoke on the shaft between the drive axles is famous for binding up on those trucks. A tell tell sign is the air bags on the rear drives will be stretched out more than the front axle bags. Easy fix is to mark where the yoke and shaft sit now. Unhook the driveline from rear yoke. Pull the shaft out of the slip yoke clean it check splines and re hook it 180 degrees from where it was.
    Reason for edit: left out something
  7. Truckin2Eat
    305
    86
    Jul 2, 2013
    GA
    When my tire guy jacked up both rear axles. He let each set of tires on both axles spin while he stood behind them. Is the way you check for out of round tires? Also how do you tell if the slip joints on the drive shaft are seized? My mechanic had also looked at my drive shaft. I'm really lost now I have been spending money really only gambling trying to find the problem.
    Heavyd Thanks this.
  8. Heavyd
    Heavyd Road Train Member
    7,626
    6,027
    Feb 4, 2009
    Yep, you have to jack up both drives on stands and run it and watch for wheels out of round.
  9. Bakerman
    Bakerman Road Train Member
    4,663
    8,806
    Jan 27, 2013
    Phoenix, AZ
    Check your ride height.
