All my lights work on tractor and all myights work on trailer except break lights and when i hit the beaks i have power to red wire what do i check next how do i trouble shoot plz help im driving around like this right now!!!!
Help break lights on trailer dont work red wire has power
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Adamprov3nch3r, Jan 18, 2021.
Put a new bulb in.
Caterpillar Cowboy Thanks this. -
Have you checked for power at the plug that goes into your brake light at the rear of your trailer?
If you have power to the light, either your light is broke or your light needs a proper ground connection.
Best way I've found is to start at the bulb and trace it back to the power source. Many times it turns out to be a bad ground connection...
Theres a stupid plug right behind the liecence plate that was bearly plugged in
Badmon Thanks this.
