HELP IS THIS TOO MUCH OIL
Discussion in 'Ask An Owner Operator' started by Nando85, Apr 16, 2018.
I would not worry about that much. But yes it is bad if it is way too full.
So if i run it hard should be fine then
Run it as you normally would. Check the level daily. Shouldn't be an issue. You don't need to hammer the engine to try to burn it off lol
Blackshack46 Thanks this. -
Hold the stick with the point down. You’ll be fine.
77fib77, Cottonmouth85 and IluvCATS Thank this. -
Ok thanks guys
I wouldn't worry about it. Not going to hurt anything.
Curious.
What happens if it is overfilled too much? Excess crankcase pressure? Which ultimately makes what happen? -
Your crank will be spinning in oil, not designed to since they did away with the old splash systems, oil circulates thru the pickup then is sent to the various places in the engine. with the crank spinning in the oil it will turn to foam, which does not pump well. Then you get a shutdown warning the the oil police come out the wonk you over the head.
Streetroddreams, Big_D409, Tug Toy and 3 others Thank this.
