help-loosing 1g of coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by The blue guy, May 4, 2015.
  1. The blue guy
    The blue guy Light Load Member
    83
    4
    Jan 4, 2015
    I continue to loose 1 gallon of coolant, every day. There is no leak anywhere, and I tested my oil and it came back as free of contaminants. Where is it going?
    Is it the EGR Cooler? Truck is running exactly the same. not overheating or any issues.
    Any suggestions are appreciated
    Thank You
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,467
    6,504
    Aug 26, 2014
    Need to know year, engine model, make, Etc. for someone who may know to to give a good answer. Maybe check the air dryer exhaust port for awhile. Buy a new radiator cap?
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    Pull an oil sample that can give you a lot of info.. If its leaking into your oil you need to change it asap it will cause damage.
  5. truckon
    truckon Swamp Thing
    4,774
    15,917
    Dec 16, 2011
    Like I'd tell you!
    He already did.
  6. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Wow got no clue how I missed that lol
    Did you pressure test? You said no leaks but should pressure test it. Could be your egr? Year miles n model?
  7. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    Coolant goes in only a few places, thru a bad head gasket, thru a water cooled turbo (rare) radiator, radiator cap or hose leak or with an EGR cooler thru the exhaust,
    You can disconnect the EGR cooler at the rear of the cooler an see if there is any moisture , an other way is to start the truck cold and see if there is any white smoke,,I replaced an EGR cooler on an 07 Cummins at 318,000 miles,,
  8. wore out
    wore out Numbered Classic
    15,846
    191,688
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If it's going out the exhaust pulling the pipe off back of turbo will show you crystallized antifreeze. My bet is your overfilling it and it pukes out what it doesn't want. Let it run a gallon or so low and see if it continues to disappear or just runs below the cap
  9. Arkansas
    Arkansas Medium Load Member
    514
    668
    Dec 20, 2014
    LA- Lower Arkansas
    I'd say wore out is probably right.
  10. The blue guy
    83
    4
    Jan 4, 2015
    2004 Freightliner Century Detroit 60 Series, 850k
  11. mirsadvic
    mirsadvic Light Load Member
    70
    5
    Dec 23, 2013
    I had the same issue in my volvo670 its egr cooler and egr valve bad good luck
