I have a 1997 Peterbilt, it has ECM, with a Detroit motor, is this considered an electronic motor?
Help Please
Discussion in 'Experienced Truckers' Advice' started by TwistedS, Apr 10, 2020.
Yes, you have to go back to something like maybe 80s to get a mechanical engine. Detroit may have been the first electronic engine, not sure. Cummins had the N14 when I started driving and it was Electronic also.
Thank you so much!
I think they just want to make sure I can put an ELD on my truck?
Now finding a computer that will communicate with those older computers? Thats the trick I think. There are still some older laptops with serial ports and such out there on the secondary market or computer shops. Obsolete by today's standards. But should work well with the onboard truck engine control module.
The problem with those early ECMs is sometimes they die. The entire Module. Its going to be about almost 2000 dollars and several days work to install and configure a new one. You can however run the older engine without a living module in a sort of a bypass smoky joe mode as long you dont shut it off until shop. And you can attempt and usually get it turned over using gravity downhill in 2nd if your batteries were bad. That would be enough to get you to a shop.
Today's computer engines in big rigs are exceeding rational logic. The more the engineers entangle themselves in their ball of electronic yarn the worse it gets for us idiots who have to deal with the castrated trucks on the road.Farmerbob1 and TwistedS Thank this.
