Help! Trouble transferring NJ cdl to TN - medical certificate not showing
Discussion in 'Experienced Truckers' Advice' started by Jay856, Jan 1, 2026.
  1. Jay856
    Jay856 Bobtail Member
    5
    Jan 1, 2026
    I’m trying to transfer my NJ CDL to Tennessee and have run into a really frustrating problem. My NJ DOT medical certificate is valid until December 2026 and is already in the FMCSA National Registry, but the Tennessee DMV can’t see it in their system.
    I called the FMCSA and they confirmed that everything is fine on their end and my certificate is valid. They told me to contact the DMV and get connected to the CDL unit so my medical certificate information could be transferred to the Tennessee system.
    When I contacted the CDL unit, they said they couldn’t find my record and told me to go back to the DMV. I called the DMV again, and this time someone told me I would have to get a new DOT physical in Tennessee.
    Then, when I tried to schedule a CDL physical, the clinic said they couldn’t perform the exam for the purpose of transferring a New Jersey CDL. The staff told me I would already need a Tennessee driver’s license before they could do the exam and advised me to contact the FMCSA again.
    This has me going in circles, and it’s incredibly frustrating, especially when DMV staff are giving me attitude and don’t seem willing to help.
    Has anyone else had this problem transferring a CDL across states? How did you get the DMV to recognize your National Registry medical certificate? Any tips would be really appreciated!
  3. Chinatown
    Chinatown Road Train Member
    77,453
    182,337
    Aug 28, 2011
    Henderson, NV & Orient
    Jay856 Thanks this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,916
    18,890
    Nov 1, 2010
    Burnsville, MN
    Since when do you have to be in the state your CDL is issued in to get a DOT physical?
    I have had several times when my med card was due to expire and I got the physical in a different state because I was not due for a home time.
    But, things change all the time. Usually for the worse.
    I had to renew my license this last December of 2025, so a couple weeks ago.
    I'm no longer driving so I downgraded it to a standard class D.
    When I told the woman at the window she said I was lucky, since starting recently was a requirement for a lot of extra documentation to renew a class A.
    She would have had to send me home for more stuff.
    Not to get the class A in the first place, but just to renew it.
    Rideandrepair and tscottme Thank this.
  5. TripleSix
    133,012
    Ok…I got frustrated reading your post, so I can only imagine your frustration. Let’s simplify things:
    Do you have a valid CDL right now? I know you’re trying to transfer, but skip all that. Is your CDL that was issued to you from the state of New Jersey still valid? If yes, go to any clinic in the USA and get yourself another DOT health card. Take this health card to the Tennessee DMV and hand it to them when you get your license transferred.
    EDIT: The only people that you need to talk to about transferring your NJ CDL to a TN CDL is the Tennessee DMV. No one else needs to know a d@mn thing. Do not mention it to any person in a clinic. Got it?
    tscottme, drvrtech77 and Chinatown Thank this.
  6. Moosetek13
    14,916
    18,890
    Nov 1, 2010
    Burnsville, MN
    That was a nice rant, but it does not solve anything.
    You do not go into the DMV and tell them to do what you want. They tell you what is required.
  7. Jay856
    5
    Jan 1, 2026
  8. Jay856
    5
    Jan 1, 2026
    Not to get the class A in the first place, but just to renew it.[/QUOTE]
    Yeah, this whole thing has been a nightmare. I’ve been to the DMV four times already trying to transfer this license. The first time I arrived there, they said to me “Ohhh…yeahhhhhh…CDL transfers are quite difficult” right then, and there I knew it was about to be some nonsense. They told me if I was getting a transfer to get a regular Non-CDL Tennessee drivers license I would’ve been fine.
  9. TripleSix
    133,012
    You have a valid CDL. If you go and get a new DOT health card, what happens? The clinic is supposed to send it to the state and they give you a hard copy, right? If the new one doesn’t show up, hand them your copy at the Tennessee DMV. Problem solved.
    EDIT: Forgot to mention…go to a different DMV office. Some times, that makes a big difference.
  10. brian991219
    brian991219 Road Train Member
    3,008
    6,143
    Aug 10, 2013
    Lords Valley, PA
    1st, getting a new medical exam in TN will not help unless you have a TN CDL. The new exam will be attached to your NJ CDL number so you will be in the same place. The way the current medical reporting system works is the examiner uploads the record to FMCSA using your name, CDL state and CDL number, which will still be NJ until you have a TN CDL. Getting a new medical in TN will not help. That said, for TN to "see" your current medical exam, they need to query the FMCSA using your NJ information.
    2nd, have you run your NJ history to make sure NJ has properly recorded your current medical exam on your abstract? TN should be able to see it when they verify the NJ CDL is valid. The issue may be that NJ hasn't properly recorded your medical exam which means TN won't be able to see it.
    If you can't get a resolution easily, and have the time to do so, try transferring your CDL to TN and selecting "excepted intrastate" which does not require a medical exam. Then, once you have your TN CDL, go get a medical exam using the TN CDL number and it should show up in their system. Then you can self-certify back to "non-excepted interstate" and have a regular CDL again. This may take a week or two, but it should get around whatever issue they are having in their system.
    If you haven't already, try calling the HQ and ask for the Commercial Driver License Unit Driver at the License Issuance and Reinstatement office. Phone (615) 253-5221 or 1-866-903-7357
    Lastly, as Triple Six recommended, try a different TN DMV location and you may find someone that knows how to make it happen.
    hope not dumb twucker Thanks this.
  11. Jay856
    5
    Jan 1, 2026
