HELP!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HoneyBadger67, Aug 11, 2020.
Is it this, maybe?
Yep, pressure protection valve. Bypass it to get you back on the road.
HoneyBadger67 Thanks this. -
Goodysnap, HoneyBadger67 and rachi Thank this.
You're absolutely correct!!rachi Thanks this. -
Tank fitting is 1/2" NPT. Probably air line for PTO or add on acc.
rachi and HoneyBadger67 Thank this. -
So that valve isn't even necessary? It's on the top of the tank with nothing coming oyt of the other side. You can even see where it blew out.Attached Files:
Not needed, plug it. Used for air accessories and doesn't allow air to flow under set PSI, usually 60-70.
The good news is, I heard it as soon as it popped and was on the shoulder before the warning bell chimed.
spsauerland and rachi Thank this.
