I was wondering if you guys use high heat anti seize for exhaust manifold bolts.
If you do use it, do you use the nickel anti seize, or the non-metal anti-seize?
High heat anti seize
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 23, 2018.
Well... that is a good question that I do not know the answer to as in many things in life. I've used the silver (nickel) and the copper (well...copper) for no other reason than that's what was available to me and has served me well over the years. Now days I see a white (lithium?) thread lube like on DPF type sensors which invariably doesn't seem to make a bit of difference when tying to remove them with the proper line wrench and a quick bump, after a good penetrate "soak". NOTHING works as good as an aircraft rivet gun ($$$-trigger control) with various designed bucking bars to "tap" each flat around anything I couldn't get broke free, has never let me down or damaged something to the point where I couldn't re-use it if necessary....otherwise I don't know if "high temp" anti-seize is available or even exist, sorry but good question.
You plan on taking your manifold off again for some reason within a year? After that forget about it. The anti seize isn’t gonna help you 5 years from now
What are you talking about? Did someone on ch 19 tell you that?
Snailexpress, swaan, SAR and 1 other person Thank this. -
