Hitch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hardy541, Oct 23, 2019.
  1. Hardy541
    Hardy541 Bobtail Member
  2. lester
    lester Heavy Load Member
    899
    2,294
    Jan 2, 2012
    NW, Iowa
    Break out the tape measure
  3. I glide 47
    I glide 47 Road Train Member
    1,254
    1,220
    Jun 3, 2017
    Probably to much, will probably hit the camper
  4. ZVar
    ZVar Road Train Member
    6,970
    12,286
    Sep 10, 2010
    Flint, MI
    Likely it will not fit. The kingpin is the same size so no worry there. The issue is clearanc in turns. If you can remove the bobtail mudflaps, and run in states where that's legal, you might be ok.
    You can also get what's called a pin box extender. That moves the kingpin up for more clearance, but they aren't cheap.
  5. truckdriver31
    4,974
    5,414
    Sep 18, 2013
    if the stinger haulers can do it. then im sure you can.
  6. starmac
    starmac Road Train Member
    6,677
    12,473
    Apr 11, 2019
    Fairbanks Ak
    Do some measurements, I used to pull mine, but don't think I could have without sliding my fifth wheel back., for your lights to work right you will have to tie in to the tractor tail lights, you can not go off of the trailer plug, just in case you didn't know.
  • Draft saved Draft deleted
