HOS 8-2 Split
Discussion in 'Trucking Industry Regulations' started by allendriven, Dec 1, 2019.
  1. allendriven
    allendriven Bobtail Member
    32
    21
    Aug 10, 2019
    Wherever
    I know this has to be redundant (someone must have asked before me). Can someone explain the 8-2 split, where it would be practical, how often it can be used, is it used with a 30 break, etc.? I stopped at a closed WS and asked a trooper there. The look he gave me made me want to run out and buy a grill guard! That wasnt pork, it was venison! Thanks in front!
    Snailexpress Thanks this.
  2. Judge
    Judge Heavy Load Member
    853
    2,191
    Newport, Ar
    If the shipper takes 5-6 hours to load, if you could make it to destination only by running 7.5 hours, just shut down for 8, dont do the 30 minute break, it’ll be in your 8 hr break, gain rest of unused hours make drop, do other 2 hr break at reciever.
    Note
    8 hr has to be SB, other 2 can be either Sb or OD.. 8 has to be first
    Bean Jr. Thanks this.
  3. not4hire
    not4hire Road Train Member
    5,791
    17,973
    May 16, 2012
    Calgary
    Not true.
    Split Sleeper Simplified
    • 8 hours (must be in the sleeper) pauses your 14
    • 2 hours does not pause your 14
    • the two break periods (8 and 2) can be taken in any order
    • the two work periods on either side of either break, added together, cannot exceed your 11/14/70
    • When using the split-break you enter into a cycle of work | rest1 | work | rest2 | work | rest1 | work | rest2 | work, etc., until you return to a "normal" schedule by way of a 10-hour continuous rest or 34-hour reset.
    25(2)+2 and Flat Earth Trucker Thank this.
  4. allendriven
    32
    21
    Aug 10, 2019
    Wherever
    Simply put, drive 7, R2, drive 4, R8, drive 7, R8, drive 4, R2, and so on till you hit 70. I like that better than 10(bored) and a 30(no time for anything). Now, how to get around an ELD that doesn't support that split?
  • Draft saved Draft deleted
