How long does an air dryer cartridge last?
Discussion in 'Ask An Owner Operator' started by 77fib77, Aug 3, 2020.
  1. 77fib77
    77fib77 Road Train Member
    3,747
    10,464
    Jul 7, 2010
    St Louis
    I replaced mine 5 months ago. I changed it today, it was pretty heavy.
    Three times the last month. Air pressure would stop building at 50 psi. Or it would build to 130. Then it would drop to 50 and really struggle to get back up. I changed the governor last week thinking that was it. But this morning I didn't get more than a mile. So now I have a new cartridge.
    Trucking Jobs in 30 seconds
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    2,936
    3,784
    Aug 26, 2014
    I do not know. A company I used to work for replaced them every 250,000 miles or two years.
    There are a lot of different dryers out there anymore. Oil in the system throughes everything out the window.
  4. Dale thompson
    1,464
    5,315
    Nov 20, 2013
    commerce twp,mi
    Cartridge life is dependent on many factors,total air consumption being the biggest variable.
    Rideandrepair, AModelCat and 77fib77 Thank this.
  5. AModelCat
    74,581
    I'd imagine if you operated in high humidity areas it would have a shorter lifespan.
    Oil wrecks the dessicant in the cartridge. Alcohol will damage it too. If you ever have to put air brake antifreeze or alcohol in the air system, put it in after the dryer.
  6. 77fib77
    3,747
    10,464
    Jul 7, 2010
    St Louis
    Diesel?
    Where does the air come from in the compressor? In my isx it came near the Cross over egr pipe. My dd15, I'm not sure. The compressor is burried under the dog house. Hard to see what feeds it.
  7. uncleal13
    uncleal13 Road Train Member
    3,103
    4,493
    Apr 9, 2009
    Humboldt, Sk
    I change mine every fall. Make sure your air tanks are drained.
    Modern trucks require the oil coalescing filter.
    77fib77 Thanks this.
  8. Midwest Trucker
    2,704
    6,611
    Aug 31, 2018
    Once per year. Really they should last longer. It’s when your air compressor gets old that you have to replace more often.
    it’s a precursor to having to replace it the air compressor.
  9. 86scotty
    86scotty Road Train Member
    1,790
    3,918
    Aug 27, 2017
    Appalachia
    I forgot about mine for about 200k. It was fine.
  10. Elroythekid
    Elroythekid Road Train Member
    1,439
    1,198
    Sep 9, 2010
    Halifax Nova Scotia
    Sounds like your compressor is passing oil. Cut the cartridge open and see what's in it. If its oily, time for a compressor.
  11. danny23tx
    danny23tx Road Train Member
    1,142
    1,462
    Feb 16, 2016
    Once a year , It's time to change here soon . Thx for the reminder.
  • Draft saved Draft deleted
