How much can I work?
Discussion in 'Flatbed Trucking Forum' started by JimiD303, May 28, 2020.
  1. JimiD303
    JimiD303 Bobtail Member
    6
    6
    May 28, 2020
    I am a telecom tech, mostly climbing towers. I have read about maximum hours per week being 70 to 80 depending on rest. I frequently work 90 plus hours per week without even touching the truck as I just use it to transport a man lift or tractor and it sits there until job is done, or it just gets driven back to shop. Am i still bound to those hours even if Im not using the truck at all? If so, is there a way around it, i.e. two job titles at the same place of employment?
    Trucking Jobs in 30 seconds
  3. Connie_D
    Connie_D Bobtail Member
    If your close to home like I think it’s 100 mile radius then your not bound to truckers hours
  4. ZVar
    ZVar Road Train Member
    7,082
    12,609
    Sep 10, 2010
    Flint, MI
    (Ignore poster above, he's wrong. He's likely talking the time card exemption, which has a 12 hour limit of being on-duty/driving per day and the 70 still applies.)
    It depends on the weight rating of the truck. Most likely with it having a man lift on it, it's over the 10,000 threshold that requires logging. I'm going off the assumption that's true.
    Now,. you have to follow all logging rules when driving the truck. That means you cannot drive after the 14th hour after a 10 hour break. Nor can you drive after being on-duty for 70 hours in an 8 day period.
    Now note the word driving. You can work literately 24/7 and not be in violation. You cannot, however, drive on public roads without the required breaks.
    Now even that assumes you are working under federal regs. I.e. your state doesn't have special Hours Of Service (HOS) and follows federal HOS. Also assuming there is no exemption for utilities.
    tscottme Thanks this.
  5. JimiD303
    6
    6
    May 28, 2020
  6. JimiD303
    6
    6
    May 28, 2020
    Most definitely over 10k, I weigh in at 79,865 with tanks full and an empty stomach, ha. No state or utility exceptions. That definitely answers my question though, I thought it pretty silly to regulate work outside of driving just becsuse of CDL. Just wanted to make sure I could still work the hours I needed otherwise I'd be giving up the CDL, thanks much.
    ZVar Thanks this.
  7. FLtoOKBound
    FLtoOKBound Road Train Member
    1,947
    7,205
    Jan 27, 2020
    West Central, FL
    The logic behind it is that even though you'te not driving. It still tires you out working.
  8. tscottme
    tscottme Road Train Member
    6,180
    9,317
    Jul 25, 2008
    Nashville, TN
    The 100 air-mile rule doesn't exempt you from Hoursbof Service (HOS) it just exempts you from keeping an up to date logbook if you meet all of the other requirements.
  • Draft saved Draft deleted
