How to fix a fire hydrant
Discussion in 'Road Stories' started by Bakerman, Jan 30, 2016.
  1. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
  3. Cat sdp
    Cat sdp . .
    20,941
    72,806
    Apr 8, 2012
    Orion's Belt
    Are they taught not to slide the tandems up...?
    I always thought if you hit a fire hydrant you would get a fountain?? But I guess not...
    NavigatorWife Thanks this.
  4. taxihacker66
    taxihacker66 Road Train Member
    1,344
    1,224
    Feb 26, 2012
    Concrete jungle.
    Maybe its one of those imitation ones for all the local K9s to use.:p
    CasanovaCruiser and NavigatorWife Thank this.
  5. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Apparently that only happens in the movies.
    I was told the valves are 2-3 feet underground for the hydrant.
    NavigatorWife and taxihacker66 Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    Yes the actual valve is under ground depending on how far down the winter frost level goes. In warmer climates it may be directly at the base.
  7. uncleal13
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    Would have helped if he had of taken the turn wider, he had more space than he used.
  8. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,080
    Apr 30, 2012
    Cental West, AL
    Did anyone see me? look he gave I think.
  9. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    No lie.... probably woulda done that too. And then called from a pay phone in the next county. 'Hey this hydrant is knocked over'
  10. albert l
    albert l Road Train Member
    1,040
    1,505
    Feb 10, 2013
    On the Road
    Well, at least he kicked the dirt back in place
  11. CasanovaCruiser
    CasanovaCruiser Road Train Member
    1,712
    2,669
    Jun 2, 2015
    Indiana
    He started with a pickup...then swift gave a bigger ride
    tucker Thanks this.
