HOW TO FIX KENTWORTH T700 ULTRA SHIFT STUCK IN NUETRAL (AUTOMATIC)
Discussion in 'Kenworth Forum' started by PrettyBoyTrucker, Feb 20, 2016.
  1. PrettyBoyTrucker
    PrettyBoyTrucker Bobtail Member
    40
    9
    Aug 31, 2015
    Raleigh, NC
    Got a kenworth T700 stuck in neutral. Happens like every other day. Shows a service light on the automatic transmission. Took it to Kenworth they plugged computer up & found no issues. But there is a problem because it keeps happening. Any suggestions???
    Trucking Jobs in 30 seconds
  3. S M D
    S M D Road Train Member
    2,360
    3,330
    Mar 15, 2012
    sacramento ca
    Push the brake? Lol.. But could be a sensor thing. Its hard with automatics because there is so many sensors and parts on there that really you have to let it break to fix it.
  4. PrettyBoyTrucker
    40
    9
    Aug 31, 2015
    Raleigh, NC
    I know you push the brake. But the service light is showing on the transmission.
  5. S M D
    2,360
    3,330
    Mar 15, 2012
    sacramento ca
    Might just be low on fluid.
  6. PrettyBoyTrucker
    40
    9
    Aug 31, 2015
    Raleigh, NC
    all fluids are up. doesn't want crank either. normally i have to wait it out & try cranking it again in 30 mins -hr
  7. baha
    baha Road Train Member
    3,720
    2,277
    Jul 25, 2013
    ga
    Your trans may not be in N, If you can have the clutch adj. it can help shifting problems?
    PrettyBoyTrucker Thanks this.
  8. PrettyBoyTrucker
    40
    9
    Aug 31, 2015
    Raleigh, NC
    it's an automatic
  9. beckstr
    beckstr Bobtail Member
    11
    Feb 9, 2013
    Maybe XY shifter harness ? Had similar issue on volvo . Dealer replaced XY shifter and harness. But I think harness would fix it.
    tech10171968 Thanks this.
  10. AModelCat
    97,542
    Do you shut off the truck with the transmission in gear? I've been told that can cause the transmission to stick in gear and it won't go to neutral when you try and start the engine again.
  11. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,096
    Feb 23, 2011
    Gulf of Mexico
    Sell it and buy a truck with a manual tranny.....problem solved!
  • Draft saved Draft deleted
