i need help locating a good mechanic in the San Bernardino or Phoenix area that can work on DD15’s. I don’t want the bs artists please.
Just someone I can trust to work in my rig that’s honest.
I’m tired of these mechanics wanting to charge 4 hours to change out a fuse or $1500 for a water pump.
A DD15 is the same as the next one, you should already know how long it will take you to change a water pump, approximately.
Any help will be appreciated thanks.
I need help locating a good Mechanic
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LoneRanger, Jul 19, 2019.
Ummm......You can do simple external things like that yourself. Unless the Newer detroits have a Wall of "fear" around the motor once you open the hood.
@Dave_in_AZ lives out that way and may can offer some insight.
What's the problema?
Well for starters need to do a valve adjustment, then other things as they come along.
Things in the works to be replaced is the rear main seal, if that’s done then a new clutch, and possibly a transmission as well.
Just need someone i can trust on the routes I’m on.
