I think I’m loosing my brakes
Discussion in 'Experienced Truckers' Advice' started by Yup68, May 27, 2018.
  1. Yup68
    Yup68 Bobtail Member
    6
    9
    Mar 29, 2018
    My brakes aren’t working right and I’m headed west of Denver on I-70 as we speak. HELP!!!!!
    IluvCATS Thanks this.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    you will be fine. just hammer down with phone in hand logged on with TTR as you exit the tunnel
  4. Yup68
    6
    9
    Mar 29, 2018
    Ok cool. They are smoking a little bit I think that’s normal
    IluvCATS and KB3MMX Thank this.
  5. joesmoothdog
    joesmoothdog Heavy Load Member
    737
    1,144
    Aug 5, 2013
    OTR
    While you're pulling yourself outta the wreckage see if you can find my mind. SMH!!! Amazing how a no brake professional can post that while screaming bloody murder.
  6. Jacoooooooo
    Jacoooooooo Heavy Load Member
    747
    1,054
    Oct 20, 2013
  7. Yup68
    6
    9
    Mar 29, 2018
    Ok I got the fire put out on my trailer. No major damage yet.
    A guy said there is two more hills to get over so I’m gonna try and slow down a little and see what happens.
    Stay tuned...
  8. rolls canardly
    rolls canardly Road Train Member
    1,608
    3,778
    Feb 7, 2009
    mt. pocono. pa.
    shill.
    Even a moron would stop.
    MartinFromBC and x1Heavy Thank this.
  9. Chinatown
    Chinatown Road Train Member
    74,670
    169,756
    Aug 28, 2011
    Henderson, NV & Orient
    Do you have a jake brake?
    Brakes smoking in an area like that is not uncommon.
    If you see a flame, keep moving, don't stop. If you pull over and stop, you won't be able to release the brakes again; they'll bond to the drums and then you have major fire problems. That's what usually happens.
  10. Chinatown
    74,670
    169,756
    Aug 28, 2011
    If you stop in that situation, don't set the trailer brakes. I've seen trucks stopped at the bottom of steep grades and the trailer tandems flaming and back of trailer in flames.
    NavigatorWife and rolls canardly Thank this.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    not true
    Lepton1 and joesmoothdog Thank this.
