Hey Guys,
So I'm new to the flat-bed world and I'm going to be hauling a getup similar to this right here: https://imgur.com/a/8rKtFOf and I'm looking for experienced drivers take on what would be good securement here. This is G70 1/2" chain, my boss wants 100% of the WLL so going across the trailer is the only option if I understand things properly. Any thoughts or ideas, or maybe I'm doing something wrong or there is something I could be doing better, would be a great help.
Thanks in advance,
Arisonius
Edit: Mods, I just saw there's a flatbed forum. This post might do better there if it can be moved?
Ideas on Load Securment
Discussion in 'Experienced Truckers' Advice' started by Arisonius, Jul 2, 2018.
70-1/2 has a wll of 11k, i don't see it happening how you have it, the points on the load you have the chains on don't look like they are intended to hold the load down, so it looks like an RV and if it is, then axles should be used.
A bus...
It's over 10000lbs, and so the law requires that you use 4 points of securement regardless of the chain WLL. You want a 4 point pull to prevent any forward, rear, side to side movement and up and down. Cover the 4 points first and then cover for the weight of the bus. Got it?
EDIT: I just realized that you are talking about doing across the trailer, an indirect securement. DONT DO THAT. You want a minimum of 4 points direct pull, and then add additional for the weight. No indirect securement.
@johndeere4020 or @Ruthless will be along to offer any other help you may need.snowwy, Lepton1, Feedman and 1 other person Thank this. -
I'm not saying that I agree, but this is an example of the 4 point direct securement required for wheeled vehicles and heavy equipment. -
I've got 4 chains. 2 up front, 2 in back, just to be sure. The ones up front aren't pictured, we're still working out how to make that secured. So we're going to try and use 4 points of indirect securement, which should be satisfactory? Unless there's some reason that's not preferable?
@TripleSix After watching that video I think I understand better why the indirect securement is not preferred, because you can't get that 45 degree angle. Interesting. I'm going to have to take this information and redo the strategy. I really appreciate the information. Thank you!
Indirect securement pulls straight down to the trailer. Direct securement pulls in a DIRECTION. On a wheeled vehicle you want direct, not indirect to prevent movement of a wheeled vehicle.
Why does direct rated at half the WLL of indirect? Because unless you have another direct pulling in the opposite direction, it's useless.LoneCowboy and Feedman Thank this. -
OP, TripleSix is correct, you don't want to just be pulling straight down. Not on a wheeled vehicle than can roll. You want the chains to be stopping it directly. If you feel that you need more securement, than you can, if the tie down points on the unit being hauled are adequate to the task, go from the trailer, to the unit, and instead just just tying off onto the securement point you go around it and come back to the trailer, at a similar point on the trailer. So that both legs of the chain are pulling in nearly the same direction. Don't go back to the same tie down point unless you have tie down points rated for that much of a pull, or they will become the weak point in your system.
BTW, you say flatbed, is this going on a step deck or some sort of set up with heavy duty tie down points? The tie down points on most flats and steps aren't going to handle more than a 3/8ths chain can, so using the big chains is useless. -
@ChaoSS It is a step with a detachable gooseneck. We're having to remove the celvice from the end of the chain and reattach it and then hook it. Curious to know, is hooking the chain to itself a no no? The second picture has a pretty good idea of what the side of the trailer looks like. We were having issues getting the hooks to play nice on those hooking points.
@TripleSix Great explanation. That clarifies it perfectly for me.TripleSix Thanks this. -
Your trailer looks like it's designed to drop the chains directly into those pockets and hook to the trailer without using a hook on that side. Do you know the ratings for those points and if they are designed for that size chain? If so there's no need to loop around and hook back to the chain like that.
