Idle dd15 get on fuel, stumble white smoke
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 77fib77, Mar 29, 2020.
  1. 77fib77
    77fib77 Road Train Member
    3,622
    9,646
    Jul 7, 2010
    St Louis
    I have a 14 cascadia with a DD15. I idled on and off over this weekend and then I get on the fuel, it stumbles puts out white smoke and then clears up. It doesn't burn oil. Also under a load it sometimes stumbles from idle to about 950 rpm, same thing white smoke clears up and runs. Truck has dpf off of it but egr is still intact.
    No oil in radiator tank.
    Oil with 3000 miles on it
    Trucking Jobs in 30 seconds
  3. Ivansoto0123
    Ivansoto0123 Bobtail Member
    9
    Sep 15, 2016
    I have the same problem but mine only does it when the temp is below freezing. If the temp is above it will run ok although I did notice a drop in mpg.Still trying to figure it out dont wanna throw parts at it. Some have suggested the egr valve might be getting stuck. Since the weather is warming up it hasn't acted up. Did you get any codes?
  4. 77fib77
    3,622
    9,646
    Jul 7, 2010
    St Louis
    I did and changed out the delta P sensor. A friend of my new has a 600 dollar scanner cleared them all. Part of me wants to buy a scanner and see if a boot leg copy of dddl software will allow me to look at the engine. Another person suggested an injector firing rich.
  5. Rideandrepair
    7,134
    11,637
    Aug 8, 2015
    I’m having the same problem, on my 2000 12.7. Seems to be worse when tanks are low, and fuel filters are old. Still takes a while to go away, after changing filters.Im pretty sure it’s caused by s leak between tanks and fuel pump. It’s sucking air, showing bubbles in fuel tanks, from return fuel with air still in it. Probably my shut off valves on top of tanks. Common source of leaks. It won’t show up unless tanks are pressurized and forces fuel to bleed out. Only sucks air in. Just a thought. Sputters, misses, lots of white smoke, then clears up after its wound up and pumping good again.
    77fib77 Thanks this.
  6. Rideandrepair
    7,134
    11,637
    Aug 8, 2015
    Check lines and filter base for a hairline crack, Ideally put air pressure into fuel tank, even a air hose, with a rag will work, to get the fuel to bleed out at the source of the leak.
    lwlevens and 77fib77 Thank this.
  7. 77fib77
    3,622
    9,646
    Jul 7, 2010
    St Louis
    Yeah the higher my davco the worse it has been. I sometimes see air bubbles in the davco filter. So it might not be the filter but lines coming into it. I didn't think of that, I assumed the filter.
    Rideandrepair Thanks this.
  8. Rideandrepair
    7,134
    11,637
    Aug 8, 2015
    Ive never had a davco, but know they are a common problem. Lot of threads on here about them
  9. rachi
    rachi Road Train Member
    3,902
    4,148
    Feb 25, 2010
    SoCal
    When I used to Idle my DPF KW all nite, it would put out alot of white/gray smoke in the morning for about 3 minutes while getting on the Interstate hammer down. Was coming from the Dpf filter.
    Rideandrepair and 77fib77 Thank this.
  10. QUALITYTRUCK
    1,406
    1,158
    Jun 14, 2009
    romulus,mi
    If "dpf off" means what I think it does, "egr still intact" should have been off at the same time. Almost impossible to have a proper "tune" without both being "off"
  11. FreightyAK
    FreightyAK Bobtail Member
    30
    29
    Aug 7, 2018
    AK
    If yours does that in the cold its likely the def heater tube is freezing. Daimler knows about the problem and has updated part
  • Draft saved Draft deleted
