If I fill my tires with helium instead of air, could I haul more weight legally?
Discussion in 'Questions From New Drivers' started by tracyq144, Sep 29, 2016.
  1. tracyq144
    tracyq144 Heavy Load Member
    884
    543
    Feb 15, 2009
    MN
    I recently hauled a load that put me over gross by 25 pounds. Luckily, the state scales were closed, but I was sweating it all the way.
    So, would helium in the tires have fixed this problem?
  2. AModelCat
    54,984
    The North
    And if a frog had wings, it wouldn't bump its ### when it hops.
    Sorry but I just have a hard time taking a question like that seriously lol.
  3. not4hire
    not4hire Road Train Member
    5,761
    17,846
    May 16, 2012
    Calgary
    Use hydrogen instead... as long as you don't have Continental tires.
  4. Broke_and_Hungry
    Broke_and_Hungry Light Load Member
    144
    247
    Feb 26, 2008
    That's day one stuff right there!! Everyone knows that.
  5. Concorde
    Concorde Heavy Load Member
    863
    1,569
    Jun 29, 2016
    West Melbourne Florida
    Don't bother with helium, just let 1.5 psi out of each tire :)
  6. Steel Tiger
    Steel Tiger Road Train Member
    2,660
    3,204
    Jun 6, 2012
    Orlando, FL
    To cut weight, try these:
    -Don't top off your blinker fluid
    -remove 5 lug nuts from each wheel (that's all 4 wheelers have)
    -don't eat b4 you cross the scales
    -make sure all your trash is thrown away (those empty soda cans add up)
    -on the topic of helium.....fill up a few dozen balloons with helium and float them in your sleeper. They'll help pull the weight off the ground.
    Do all these and you can save up to 1.5 lbs.
    Hope this helps
  7. x1Heavy
    x1Heavy Road Train Member
    30,369
    34,395
    Mar 5, 2016
    White County, Arkansas
    Helium by atomic weight or mass is lighter than Room air. Which is a mix of nitrogen (75%, oxygen approx 20% and rest other gases)
    You will run into thermal problems pretty quick with helium. The weight of air vs helium is negligible. You would save more weight tossing out that trashbag you have been sitting on last few days. The gain in tare is negligible.
    Me thinks you have been thinking way too hard. Take some time off, relax enjoy a woman back home or something a while. Take a load off.
  8. AModelCat
    54,984
    The North
    Don't forget to throw out the lot lizards before you roll onto the scale!!!
  9. x1Heavy
    30,369
    34,395
    Mar 5, 2016
    And that foot high stack of paper forms handed to you back in orientation, toss that too.
    Then see if you can get a bucket of wrench grease.
    Waggledaddy Thanks this.
  • Draft saved Draft deleted
