I have one question that really matters......does the company feed you while you do your 10 day training....and if not? I know they give you 200 dollars is it in cash or check?
Im going to watkins shepord with only 100 dollars
Discussion in 'Watkins & Shepard' started by JOGOHARD, Apr 15, 2013.
Your on your own for food. There is a Walmart nearby for grocerys. You get $100 the first day then $100 the next week. Good luck!
Keep it cheap and you will be ok. I got there with less than $100, and made it through.
That should be fine. My class stayed across the street a the La Quinta which had a free full breakfast. RL was always there bright and early. I stocked up for lunch and snacks.
Should work out fine, as others gave good advice.
I just hope you have a backup plan if it goes south..
Seems like that's your last $100.... -
I will be there in 2 weeks. Good luck to you.
jomar68 Thanks this. -
RL sure does take advantage of that free breakfast! I feel like there were a few people in orientation that just came for the money
R.I.P. Hank
How about a status update? That is if you're still around.
