improving Sirrius reception
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by longbedGTs, Jun 8, 2008.
  1. longbedGTs
    longbedGTs Heavy Load Member
    974
    717
    Texas
    I finally got a Sirrius unit and have been having reception problems with the FM reciever. You know, you turn your radio to a set station, then tune the Sirrius unit to that same station. Well, I have had to put the FM reciever RIGHT next to the radio antenn(mounted on the mirrors). Actually, I have it strung outside and taped to the metal base of the antenna because that is the only place it will get good reception. So, for the most part, it is nice and clear, but sometimes(seems to be around big cities) it will turn to static. Is there any kind of adapter I can get to tie this directly in with the antenna? From what I understand, the radio transmitts a signal which is picked up by the Sirrius reciever, right?
    TIA~
  3. walleye
    walleye Road Train Member
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    You can get a adapter to put inline with the radios fm ant wire, they also make a casette adapter. the best way is to use a front input jack if you have one. Radio Shack should be able to help you out.
  4. Phil1Fla
    Phil1Fla Light Load Member
    298
    53
    May 12, 2008
    Beavercreek, Oregon
    They also have a inline device that all you have to do is unplug the antenna plug in the device and plug in your antenna into the device. It is what I use..Or did use I had to give it up to the wife....:biggrin_25521:
  5. longbedGTs
    974
    717
    Texas
    Oh, I have one of those casette adapters at the house, but wont be back there for a few weeks. It was for using a portable CD player run from a tape player. Would that work? Unfortunately, I cant remove the radio from my truck. Its a company truck(04 Freightliner) and I dont want to start messing with things I shouldnt. Meanwhile, Ill keep an eye out for a casette adapter. Thanks!
  6. walleye
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    That might just do the trick!!!
  7. longbedGTs
    974
    717
    Texas
    Well, I managed to find a casette adapter at a Pilot, so I snagged it. Now, there isnt a hint of static, so it did the trick! Thanks! Now, what will I do when I get a truck with a CD player? Maybe the FM transmitter in the radio will be better...
  8. walleye
    3,028
    4,306
    Aug 21, 2007
    Land of Cheese
    Hope it has a front auxilary input.
  9. SILVER EAGLE
    SILVER EAGLE Bobtail Member
    36
    Jul 14, 2007
    Pa
    if it happens again do the easy thing....buy a Xm...sorry couldnt resist
  10. droy
    droy Heavy Load Member
    828
    159
    Jun 11, 2008
    Iowa, LA
    Longbed, if your Sirrius reception is worse than my XM, you have my sympathy!
    The XM reception in my W900 SUCKS! (please note that "SUCKS" is in caps!) Currently using 3 antennas, I have the FM direct adapter, which supposedly uses the FM/AM antenna, the XM windshield antenna, and the magnetic antenna, which I just moved from a fruitcake lid on my dash, to a metal plate attached to a mirror bracket on passenger mirror. After much trial & error, this seems to be the best setup, short of buying another external antenna. Approx, 8 or 9 songs out of 10 are heard without losing reception, however I have read that the little antenna wire won't hold up to outside elements very long, not to mention truck washes, tree limbs, etc.
    I have also read that if you have a fiberglass roof, a'la the W900, you can attach the magnetic ant. to a 3" metal plate, and put it up in your overhead console, supposedly with no reception loss. I'd sure like to hear from anyone who has that, or any other setup that works.
  11. JTode
    JTode Bobtail Member
    37
    Mar 10, 2008
    Winnipeg, MB
    If you're doing long haul, you're best off with (as others have suggested) a direct FM connection, cassette adapter or aux line input, either on the front or in the back. The nature of long haul is that you're going to be constantly encountering new FM stations as you travel cross country, and this will wreac havoc with your reception.
    Honestly, you'll find it's worth it to get a new head unit with an aux input if you don't have one.
