In need of advice
Discussion in 'Flatbed Trucking Forum' started by chucomom, Nov 28, 2019.
  1. chucomom
    chucomom Bobtail Member
    31
    60
    Nov 28, 2019
    Ok guys...I'm still a newbie..so be nice...most of my experience is pulling smooth bore tankers. Well the company I'm with now has me pulling all types of trailers. Well I'm currently hooked to a step deck flatbed hauling a trailer tandem. Got about a 10 hour drive ahead of me
    .im doing all I can to maintain my lane but the rear of this trailer sways quite a bit. Any advice on how I can control this better without having white knuckles on the steering wheel. Thanks
    FerrissWheel Thanks this.
  2. pavrom
    pavrom Heavy Load Member
    994
    1,180
    Apr 29, 2012
    NE illinois
    ...could be trailer alignment ...
    FerrissWheel and chucomom Thank this.
  3. JonJon78
    JonJon78 Road Train Member
    3,316
    14,082
    Jul 1, 2018
    Is your 5th wheel greased? A "dry" 5th wheel can contribute to that.
  4. TripleSix
    91,712
    Is the trailer loaded heavier on the trailer axles than the drives? That's the 'Tail Wagging the Dog.' What can you do?
    Do not try to counter the sway. You have to become extremely smooth on the steering. Any kinds of countersteering makes the tail wagging much worse.
    magoo68, FerrissWheel, booley and 4 others Thank this.
  5. chucomom
    31
    60
    Nov 28, 2019
    They loaded trailer tandem at the end of the flatbed...I'm trying to be as easy on the steering as I can. Definately a learning experience
  6. TripleSix
    91,712
    Bare minimum steering input should smooth things out as much as possible. Be extremely careful in any bad weather.
    Luck in battle.
  7. RollinThunderVet
    RollinThunderVet Medium Load Member
    648
    816
    What's a stepdeck weigh 12-13k? No way she should be experiencing that with that little weight. Sounds like loose trailer suspension, maybe broken weld on the trailer axles?
    Landincoldfire and chucomom Thank this.
  • Draft saved Draft deleted
