Increase in the level of Engine Oil
Discussion in 'Mack Forum' started by RayMc, Jul 24, 2015.
  1. RayMc
    RayMc Bobtail Member
    Hey guys,
    I have a 1994 Mack CH with an E7 engine. Recently i realized that the engine oil has been increasing on the dip stick. I made some checks and I was told that it was seal in the lift pump that had gone bad causing fuel to contaminate the engine oil. Are there any other possible reason that would cause me to see an increase in the level of engine oil?
  3. poppapump1332
    poppapump1332 Road Train Member
    2,986
    2,464
    Jan 2, 2010
    birdsboro,pa
    Antifreeze could be getting into the oil also but chances are its fuel
    RayMc Thanks this.
  4. AModelCat
    166,503
    I don't have much experience with Macks but I have seen injector lines and fuel return lines under the valve covers of engines leak and contaminate the oil.
  5. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    If it's fuel you can usually tell with a white paper towel.
    Take your dipstick and wipe it through the towel as straight as you can. Let the oil soak in and look for a "halo" around the dark oil mass.
    If you see it, it's virtually a gaurantee you have fuel contamination to the level it needs immediate attention.
    The most scientific and definite way to find out is a oil analysis and it will give you the contamination percentage.
    BoxCarKidd Thanks this.
  6. Alaska76
    Alaska76 Road Train Member
    1,228
    1,654
    Jan 20, 2014
    Inland Empire, WA
    If there is enough fuel intrusion getting into the crank case to raise the level noticeably, an strong odor of diesel should be evident. If it is anti-freeze contamination, the emulsion would look like chocolate milk, easily recognizable.
    If the oil looks like oil, my money is on fuel contamination.
    G/MAN Thanks this.
  7. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    Best thing is to do oil analysis
  8. blessedman
    blessedman Light Load Member
    297
    230
    Feb 15, 2013
    Doniphan, Mo
    Fuel in the oil. If it were coolant the oil would be milky colored.
  9. CruisingAlong
    CruisingAlong Medium Load Member
    374
    441
    Oct 17, 2014
    Tampa , FL
    Man.. if I had a truck doing that, I would allow it to overfill, drain off a gallon at the time and then sell the extra gallons of oil produced by your engine at the truckstop.
    truckon and Alaska76 Thank this.
  10. Alaska76
    1,228
    1,654
    Jan 20, 2014
    Inland Empire, WA
    Hahaha! Funny stuff right there!
    CruisingAlong Thanks this.
  11. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    How soon are you going to get it fixed? That much fuel in the oil will destroy an engine in no time. I would drain the oil and put fresh in with at least one or two gallons of Lucas till you can get it fixed, but get it done asap.
