International 8100 fan solenoid
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mission_creek, Aug 28, 2026.
  1. mission_creek
    mission_creek Light Load Member
    55
    19
    Feb 22, 2021
    Hello, the engine fan is constantly on this 99 int 8100. The fan solenoid is missing an air line. Assuming it’s the supply line but can’t seem to find where it feeds from?
    Deere hunter Thanks this.
  3. 062
    062 Road Train Member
    6,440
    34,456
    Oct 20, 2013
    Maybe @Heavyd knows the original location. The supply line would have to be capped or the port it goes to plugged.
  4. mission_creek
    55
    19
    Feb 22, 2021
    I put air to the end of the solenoid that was missing while the truck was running. Solenoid did not release fan. Maybe it’s faulty or that’s not the supply line that’s missing?
  5. Star Rider
    Star Rider Road Train Member
    1,925
    22,465
    Sep 23, 2019
    If it's got a Horton like this one check if it has bolts where the red circles are.
    Those holes are for bolting the clutch solid and on all the time.
    If it does then you probably have a bad fan clutch.
    Put 12 volts and ground to that solenoid while the truck is aired up and it will tell you whether the supply line is hooked up or the line to the fan is.
  6. Deere hunter
    2,703
    16,302
    Aug 5, 2017
    Shallowater Texas
    I would imagine the solenoid went out. Instead of replacing it they just took the supply line off so the fan would engage. So when you hook the supply line up, it will probably disengage the fan if it's working properly. You may just need a new solenoid. You can run a supply line from anywhere as long as you have pressure.
    Star Rider Thanks this.
  7. Star Rider
    1,925
    22,465
    Sep 23, 2019
    If he has the older horton fan clutch like the one in the pic I posted, it took air to engage them. That's why they had the tapped holes to bolt them solid if they failed.
  8. Deere hunter
    2,703
    16,302
    Aug 5, 2017
    Shallowater Texas
    You are right. I hated Hortons.
  9. Heavyd
    Heavyd Road Train Member
    7,843
    6,298
    Feb 4, 2009
    Air supply for fans is usually secondary air, or the orange circuits. You can get it from any secondary supply line, it really doesn't matter.
    062 Thanks this.
