Not sure whats going on but every time the outside temp drops below 45 or around there, the Jake Brake stops working and so does Cruise Control.
Any idea what is going on? I checked the sensor by the brake pedal and everything seems good.
International 9200/9400 No Cruise or J Brake when cold
Discussion in 'Ask An Owner Operator' started by czego82, Nov 10, 2019.
Page 1 of 3
There is also a switch on the clutch pedal too. If you have a clutch pedal that is.
x1Heavy Thanks this. -
So she is a wee bit cold.
You will be fine. Just manage what is left to you as you drive. -
I don't know of any repair prodecudre for being too cold other than spend time in a shop warmed by a wood stove a while. Sometimes pulling a semi tractor into such a shop for a few hours helps with the diagnosis. -
Possible its programmed to do that?
Page 1 of 3
