inverter fail/generater?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by trucknerd, Oct 11, 2014.
  1. trucknerd
    trucknerd Bobtail Member
    8
    Apr 13, 2014
    I'm currently in a 2013 Kenworth t680. I am a company driver and was given the truck to use with 90k miles on it. It has 3 12v outlets one of which did not work when I got the truck. While using my laptop via a 300w power drive inverter I shorted out one of the 2 remaining outlets. I am worried the last outlet will also short out or maybe cause a fire. Being a company driver I cant use an inverter that plugs directly into the battery. I think my only option at the moment is to use a generator, but I dont know how that would work. Where do I keep it while it runs? Does anyone have a solution?
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    well you could look behind the glove box and see if the fuse is blown before reinventing the wheel
  4. trucknerd
    8
    Apr 13, 2014
    I assumed it was a short because it was so hot when I unplugged it after it stopped working.
  5. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    If you're running a heavy duty "gaming class" machine, you're going to have issues trying to run it through a "lighter plug inverter". I assume you are not trying to run anything else along-side the laptop on the same circuit? Do not put a larger sized fuse on the lighter plug circuit then the fuse panel calls for.. The internal truck wiring can only handle so many amps before it gets hot and then you have REAL issues.
    trucknerd and Raiderfanatic Thank this.
  6. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    The fuse box is. under a panel on the wall next to the cluth.. towards the door.. another is under the bottom bunk .. drivers side.. another under hood .. drivers side
    trucknerd Thanks this.
  7. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Also, could be the driver before you had power issues and only had UNDER-sized fuses available and this is why your 300 watt inverter is blowing fuses. Again, make sure the lighter fuses are of the correct size. Not too small, not too big.
    And, it's all too common for many of the cheaper inverters to have bad/faulty internal overload protection, thereby blowing truck fuses where a circuit breaker should have kicked off first.
  8. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    As others said, chk the fuses. Another tip is to charge while in transit . Truck on voltage is higher and thus will require less Amps for the same watt output. (V*A=watts). If plugged in while truck is off remove batt. Don't try to charge laptop batt and use it at same time
  9. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    i run a 400 watt invertor. and have never pulled my batteries out of my laptops. i'll even drain em while watching a movie and plugging speaker jack into the radio. eliminates the static noise. then plug in and surf the net.
    one of my laptops, won't even turn on if the battery is out while plugged in.
  10. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    If your a company driver it's not your truck. Report the problem on your daily log and make sure the company knows.
    lovesthedrive Thanks this.
  11. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    How hard is it to get to the truck batteries?
    Run a wire(s) down to batteries while on the road..run your inverter and then stop a mile from the yard on your way in and remove the 2 wires to battery.
    Problem solved.
    Dark_Majesty_06 Thanks this.
