Inverter fault light
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Vilhiem, Jan 15, 2015.
  1. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    So, for christmas my old man got me a 400w inverter and a small (4-cup) coffee pot. ...I'm a coffee person, regardless of if I feel I need a cup or not I love the taste of good coffee. (Drip-brew isn't great, but it's better than peelot and others!)
    I know these coffee pots pull quite a bit to power the heating elements inside, but he and I were both under idea (after some research) that the inverter would support the use of the coffee pot.
    That being said, I'm a company driver. All I can really use is the 12v plug and I can't adapt the truck in any way to suit the inverter "better."
    Here's my issue:
    I plugged the pot in and started to attempt to make coffee. Within two seconds of the coffee maker coming on, the "fault" light came on and I saw the in-cab light (the only other thing I had on.) dim. Immediately I pulled the power on the inverter and things restored to normal. There's no noted damage to the truck itself, and yes I had the rig running. I had a feeling that the batteries alone weren't going to power the coffee maker.
    My assumption, from this, is that the inverter can't supply enough power OR that the alternator isn't enough to supply the needed power. (SNI told us that there's a limit on the inverters we can add, I believe I am within that level.)
    I am going to use the pot tonight at home to make myself a brew and take it with me. It's possible that there's a short in the coffee maker too, but I'll know more later.
    Right now, I'm just looking for some advice on the matter. I would, and am willing to, buy the roadpro coffee maker and not use the inverter. (But, Christmas gift.)
    Thank you in advance and I do apologize if this has been resolved and asked before. I did do a quick search, but found nothing applicable. I'll be checking this when I shut down later tonight, I have a run leaving soon.
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    coffee pot needs more power than a 400W inveter, IIRC a 750w is the min. that heating elemtent takes a lot to get going
    Vilhiem Thanks this.
  4. TNMT
    TNMT Light Load Member
    226
    229
    Nov 11, 2008
    Front of keyboard
    A 12 cup house coffee maker at least a 1500w inverter it will burn it out after a couple of months because its not getting full juice. A house micro wave at least a 2500w inverter. 400w cell phone,maybe a lap top my laptop will barely work with a 750w. I was given a small 4 cup peculator type. Old fashioned one with the metal coffee ground holder and little glass peculator thingy on the top. 750w would work just fine. Good luck finding one. Roadpro? My experience is it takes forever and it only barely hot. Threw it away in disgust. Look for a cheap one. Dollar General or Family Dollar with the least amount of features. Not too expensive if you can't get it to work. Now bear in mind how well its grounded also affects performance. Cig lighter plug you don't or can't correct for that.
  5. Vilhiem
    3,992
    10,904
    Oct 6, 2014
    Yeah, as I unwrapped it I did ask him if it'd work. He claimed he'd used a similar setup and showed me some documentation somewhere but I did have the sneaky suspicion it work not work.
    My understanding is that coffee makers use 100w per cup give or take for any addons. Otherwise this one is very basic, just an on and off switch.
    Cest la vie. That sucks. Oh well, I do like percolated coffee. I can use less grounds since it's stronger.
    Thanks you two!
  6. TNMT
    226
    229
    Nov 11, 2008
    Front of keyboard
    Who know you might be able to find one on EBay. Like mine. The only draw back it doesn't shut down like a bigger peculator so I had to experiment with how long to let it perk.
    We use a 22 cup peculator at the house on weekends. Drip when on the weekdays cause its faster.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    A cigarette lighter plug can only support 150 watts. You need to wire it direct somewhere. Preferably the batteries, perhaps on a main line to the fuse panel.
  8. supersnackbar
    19,076
    46,910
    Aug 19, 2007
    Your Town, USA
    I've had the same microwave for a very long time. Ran it off a 1000 watt (direct wire) inverter w/o issue. Also have a 4 cup (they say 4 cup) drip that I ran off of it too(not at the same time)...my company truck has a built in hard wired 1200 watt running the same microwave without problems. A small inverter like that is good for a tv and blueray/dvd and a phone charger or a small/mid sized laptop (mine needs 90w). Much more than that, they are correct, will need a larger, hard wired unit.
  9. Vilhiem
    3,992
    10,904
    Oct 6, 2014
    Ah well crud. There goes good coffee. Heh. SNI doesn't do inverters that are hardwired in unless you're lease or o/o I believe.
    Im home often enough to where I should be able to make my own though. At this point I'm considering leaving SNI after my 6 months newbie purgatory are up. That's what my gut tells me at least.
  10. TNMT
    226
    229
    Nov 11, 2008
    Front of keyboard
    Yea ran a house microwave on a 1500w for a while. It did work but it ran at reduced power and took longer to heat things up. Moved up to a 2500w and it ran full strength. You can get most things to run at lower W but you risk whatever your running an early burn out. Safety tip one oh one. If you plug it in check the inverter connection wires and appliance plug in cord. If any are hot or if they become hot after awhile you need to stop using it until you figure out what is causing the problem.
