Inverters, APUs, Fridges in Stevens Trucks
Discussion in 'Stevens' started by The Gryphon, Nov 26, 2011.
  1. The Gryphon
    The Gryphon Heavy Load Member
    822
    443
    Nov 3, 2011
    Does Stevens have/allow the following in their trucks:
    Wire-in inverters (say 1500-2000W)?
    APUs?
    Fridges?
    Microwaves?
  3. S3Zyklon
    S3Zyklon Light Load Member
    57
    7
    Oct 30, 2011
    Leeds, AL
    From what I understand, they already have EPU and inverter in most or all of their trucks. I also think the T660 and T700 either comes with, or has an option for fridge and TV. So the trucks may either have them already installed, or they have perfect space for them. I know the T700 has atleast an optional TV mount above the slide out shelf, and a fridge fits perfectly across from that.
  4. The Gryphon
    822
    443
    Nov 3, 2011
    Wow! If that's the case, that's awesome!
    So, I guess one just has to cross their fingers and hope that the truck they get has the options for TV and fridge?
    Or does the driver buy those "options"?
  5. maxwelltie
    maxwelltie Medium Load Member
    416
    339
    Mar 13, 2010
    Brookings, OR
    All trucks have an APU and 1500w inverter installed.
    You can put your own micro, refer and or TV, playstation or whatever in there.
    The T2000 and T700's have a space where a refer can fasten in. There is upper space where you can put a micro and TV. Any appliance you install is at your cost and cannot permanently 'change' the interior.
    That means no cutting holes, tearing out walls, or whatever.
    The space for the refer has a shelf in it. You can remove the shelf, keep the screws and re install it when you turn your truck in. The upper space is large enough to set a micro in. There are belts already in place to hold your micro or TV in place. Just cinch them down.
    I have a Waeco refer in my T2000, with a Walmart micro. I don't have a TV.
    Hope that helps.
  6. The Gryphon
    822
    443
    Nov 3, 2011
    That's very helpful and really good news! Sounds like Stevens understands what their drivers need/want in terms of "creature comforts" and tries to provide reasonable accommodations.
    Is your "Waeco refer" one of those expensive ones built specifically for trucks that plugs into the wiring harness or does it plug into the inverter? Does it have a freezer to keep a couple of frozen dinners in?
    If you don't mind my asking, where did you get it and what did you have to pay for it? If it's none of my business, I won't be offended if you say so, you've been more than kind to provide the info that you've provided so far! :biggrin_2559:
  7. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    I have the same refer, only mine says: Kenworth. Built by Waeco.
    It's made to fit specifically into the truck. It comes with a 12v plug in, but when Stevens orders their trucks, they don't include that wiring harness so you need to purchase a separate converter. About the size of a pack of cigarettes.
    It plugs into 120v and converts the power to 12v for the refer.
    I have mine plugged into the inverter.
    Yes, it has a small freezer area. I can put three one pint tupperware containers in there. Keeps it good and frozen.
    I purchased mine at the Boise Kenworth dealer. It had been sitting there and he played "Let's make a deal".
    You can find them on line from Iowa 80.
    A little spendy if you compare them to the 12v models from the truck stops, but it works like a champ.
    It's paid for itself many times over. I keep drinks, condiments, cold cuts, hotdogs and even a premade salad or two in there.
    It locks so it won't fling open while going down the road.
    The Gryphon Thanks this.
  8. The Gryphon
    822
    443
    Nov 3, 2011
    Great! Thanks for that excellent response. That sounds like a great setup.
    Now, I just need to get a job offer from Stevens, huh? :biggrin_2559:
