Is It OK To Deflate A Hot Drive Tire On My Truck?
Discussion in 'Questions From New Drivers' started by PianoManCJS, Jul 29, 2026.
  1. PianoManCJS
    PianoManCJS Medium Load Member
    439
    445
    Jan 13, 2025
    I've heard the phrase "Never deflate a hot tire."
    If my drive tires are about 100psi when cold and about 110psi when hot (after a long drive) and one of them is 105psi when cold and 115psi when hot, is it not okay for me to deflate the one tire that is 115psi down to 110psi to match the others or will "deflating that hot tire" damage the tire in some way or will deflating that hot tire cause the pressure/temperature inside to change too quickly and cause the tire to rupture?
    Similar question: I was looking at some tire manufacture charts and some were saying that with a light load a drive/trailer tire only need be at 75psi? Is that so? I just got into a new Volvo VNL 860 and I know there's an extra 230lb on the cab because of the "parking A/C system" but dang...whoever filled the drive tires last got them up to 115psi...some even 120psi cold.
    Woobie Thanks this.
  3. Woobie
    Woobie Medium Load Member
    663
    1,593
    May 3, 2013
    RVA
    I'd say don't deflate the tire, wait until they're all cold and set them all to the same pressure. A tire set to a lower temp when cold will generate more heat due to excessive sidewall flex compared to a tire set to a higher pressure, that extra heat will increase the pressure in the under inflated tire more than the others. After setting them all to the same cold pressure and running them for the day if you still have one higher than the others then you have something else going on. For example, inside tires get more heat off the brakes than outside tires, so if you've got one inside tire running hotter than the others, you might have a brake or bearing issue on that wheel set. Might want to consider getting a cheap infrared temp gun from Hobo Freight for checking heat, they're also good for checking your brakes for equal adjustment and can be used for determining a cylinder misfire.
    To answer your second question, I've always run my tires at maximum cold sidewall pressure, on a light load or empty you could run them lower, but then you'll just have to air them up again next time you run heavy, so not worth the hassle IMO.
  4. PianoManCJS
    439
    445
    Jan 13, 2025
    To the first: Thanks
    To the second: I ran mail loads 2 years ago...never above 15,000lb loads. Always light. So, I'd never wish to run the drive psi at max cold rating listed on sidewall because then I'd be running over-inflated...especially if I never had a heavier load...but, regardless, 75psi seems really low for manufactureres to list in charts for tires.
  5. Toomanybikes
    Toomanybikes Road Train Member
    2,644
    3,909
    Apr 8, 2009
    You'er overthinking everything.
    Swift is resposible for your tire pressures. They usually send out there worst mechanic in the bunch (and that is a tough call in the Swift world) to check tire pressures at the terminals. Yet Swift drivers fuss over 5psi on the regular.
    5 or 10psi is not going to change a thing. Just make sure they are inflated and don't have cords showing while at a Mega company. That is a nuff of a challenge.
    They say don't deflate tires while hot because the excess pressure is often the result of the tire's elevated temperature. Nothing damages the tire, but it is likely to be under inflated when it cools down.
    Why would you want a 75psi truck tire? You haul light one day no problem. Next load will be so heavy you have to partially fuel to even look legal. Are you going to spend the time re-inflating 18 truck tires to maximize efficiency or risk a ticket for under inflated tires?
    Lonesome, Sons Hero, OldeSkool and 2 others Thank this.
  6. Big Road Skateboard
    8,010
    46,979
    May 2, 2021
    Y'all actually check tire pressure?
    Feedman, Sons Hero and OldeSkool Thank this.
  7. Suspect Zero
    Suspect Zero Road Train Member
    2,546
    9,914
    Oct 10, 2016
    Brookfield, IL
    Only if it's flat on more than just the bottom.
    Feedman, Sons Hero, OldeSkool and 2 others Thank this.
  8. PianoManCJS
    439
    445
    Jan 13, 2025
    Why do I want to have lower psi (like 85psi) all the time? Because the trailer load can be the same exact weight everyday...for instance...when I drive marching band trailers...same load everyday.
  9. PianoManCJS
    439
    445
    Jan 13, 2025
    When you switch to a new truck, sure...or if you slip seat everyday...different truck everyday or everyweek...and bumping the tires can only show if a tire is 30psi below other tires...so to get more accurate than 30psi I occasionally use the pressure gauge.
  10. Toomanybikes
    2,644
    3,909
    Apr 8, 2009
    You running a band trailer for Swift?
    What you planning to gain with lower pressures? You think you will feel a ride difference?
    Tire rating only drops down around 200 pounds load for 5psi. It is not something that is really tunable for benefit.
    All you will see from lower truck tire pressures is more understeer from the steer tires more sway in the corners. Not really a benefit.
    OldeSkool and tscottme Thank this.
  11. PianoManCJS
    439
    445
    Jan 13, 2025
    No, I'm not hauling a band trailer with Swift...I was hauling a band trailer when I was hauling for a marching band.
    I plan on running according to what the manufacturer recommends...if they recommend a certain oil in the engine, I'll use that. If they say add anti-gel in the diesel tanks below a certain temperature, I'll do that. I'm not running lower pressure because I plan to gain anything, but because I'm doing what the load/manufacturer call for. And since the load is always the same weight (for the band), I may as well set the tires for that so that they aren't over-inflated and get center-tread wear.
    The steers never drop too far below 11,000lb if at all with a trailer so I wasn't talking about lowering the pressure in those...I was talking about drives/trailers.
    Thanks
