Ishift clutch need be calibrated?
Discussion in 'Volvo Forum' started by yoandy, Aug 25, 2019.
  1. yoandy
    yoandy Bobtail Member
    8
    Aug 25, 2019
    Hello guys. Thanks in advance.
    I have volvo 2013. 490k miles. Ishift. ATO2612D. I need replace the clutch. But some mechanic said clutch need to be calibrate after installed, but other guy said this clutch no need calibrate.
    What true is this??
    Mechanic want extra charge me??
    Thanks
  3. nasriza
    nasriza Road Train Member
    2,133
    1,721
    Feb 1, 2013
    Chicago, IL
    If u don’t trust the mechanic and u are asking for our opinion go to a different mechanic. Good luck.
    THANASSIS, KB3MMX, Opendeckin and 2 others Thank this.
  4. yoandy
    8
    Aug 25, 2019
    Thks guys. But 2 mechanic told me diferent thing. Put me on dude. Jajaja.
    I was searching in internet yesterday all night. And i found original pdf from volvo ishift transmision. 350 pages. This manual said no need calibrate. Only need calibrate ATO3xxx for d16.
    Now i need find who want replace the clucth. Some one good in volvo.
  5. nasriza
    2,133
    1,721
    Feb 1, 2013
    Chicago, IL
    Clutch always has to be programmed when replaced, most of the time you can do with volvo software some trucks need to reload new software into Trans control unit, when that happens than i have to call volvo to come over here for that part which is an extra charge besides that the programing comes with clutch replacement unless need to put in updated software, but it changes from truck to truck nothing that i can know for sure until i have everything done and i go to calibrate if it takes it than its fine if it doesn't than need software update.
    magoo68 and KB3MMX Thank this.
  6. Mudman78
    Mudman78 Light Load Member
    106
    101
    May 23, 2016
    The transmission ECU may or may not need a software update. This has nothing to do with the clutch. When you remove the trans and/or replace the clutch actuator and/or replace the clutch. It has to be calibrated. This can be done with Premium Tech Tool w/programming upgrade, but unless you work on Volvo's, it's not worth the cost to do just one truck.
  7. vandambaghdad
    vandambaghdad Bobtail Member
    30
    12
    Aug 3, 2019
    Windsor,On Canada
    hi , first go to any mechanic ask him to calibrate the clutch , in the mechanic computer screen it will shows how much the clutch life and mechanic will let you know if replace need or its still have life on it no change the before calibrate. good luck
  8. Mudman78
    106
    101
    May 23, 2016
    That can only be done if the mechanic has Tech Tool diagnostic software. Some small shops don't.
  • Draft saved Draft deleted
