ISX CM871 Oil In Coolant
Discussion in 'International Forum' started by CraigInReston, Apr 17, 2022.
  1. CraigInReston
    CraigInReston Light Load Member
    136
    134
    Apr 6, 2017
    Hi guys. Just recently started getting a skim of oil in my surge tank. Coolant hoses are now getting soft and sweating an oily residue. Everything seems to point towards the oil cooler. My question is: How do you verify it is in fact the oil cooler? I was thinking of removing oil filter, then pressurizing the coolant system with air at the surge tank, looking for coolant loss from the oil filter head. Cross contamination could be coming from any number of areas: air compressor, turbo, water pump, head gasket etc. Any other suggestions towards testing would be appreciated. Would really suck to replace, then find out it's a head gasket.
  3. Big Road Skateboard
    1,510
    5,859
    May 2, 2021
    You normally see the sweating and soft hoses after fuel has been in it a while, not so much with oil.
    Either way, if it's oil, as you stated, the oil cooler is most likely. Don't rely on the cross contamination theory.
    If it's fuel, it'll be injector cups.
    CraigInReston Thanks this.
  4. Dave_in_AZ
    189,223
  5. Heavyd
    Heavyd Road Train Member
    7,395
    5,708
    Feb 4, 2009
    You would have to remove the oil cooler to pressure test it.
  6. Smellfunny
    Smellfunny Road Train Member
    1,176
    649
    Jan 28, 2012
    South Carolina
    We made up some plates to test them with. Took some plates and drilled a hole in one of them and then welded a tire valve stem in the hole. Basically the same design for our charge air cooler tester. But with the charge hoses necessary to connect to cooler and a pressure gauge : )
    CraigInReston and Heavyd Thank this.
  7. CraigInReston
    136
    134
    Apr 6, 2017
    Hi HeavyD. I made my own test plates and submerged in water with 100psi air pressure. No leak in element at all. The gaskets looked a little sketchy, so I’m hoping with all new gaskets, the leak is fixed. Any other suggestions what to look for, if this doesn’t correct the issue?
    Heavyd Thanks this.
  8. Smellfunny
    1,176
    649
    Jan 28, 2012
    South Carolina
    I have seen the cooler be good and the gaskets leak plenty of times. Been a while since I did one but there is something about sealer or something that goes on the bolts that hold the cooler on to the plate if I remember correctly.
  9. Heavyd
    7,395
    5,708
    Feb 4, 2009
    Yes, the gasket is the likely failure point. If it were me, I would replace the element regardless due to age and for the simple reason you have it apart now away.
  10. God prefers Diesels
    3,601
    17,949
    Jun 26, 2020
    South Texas
    Correctomundo, as long as it's the stainless cooler. Quickserve says to not replace a cooler that's not leaking, however I agree with @Heavyd . You've already got it apart, and coolers are cheap. Replace it.
    CraigInReston, Heavyd and Smellfunny Thank this.
  11. CraigInReston
    136
    134
    Apr 6, 2017
    Hi HeavyD. Truck is back together, even painted all the components so it looks like a brand new engine (on one side! Lol!) Yes, it appears that it was only the element gaskets that failed. Thanks for the advice! Now a new problem. I had the fault code for throttle position sensor below limits, losing response. Just let off throttle for 5 seconds and power came back. It did this randomly several times, while under heavy boost. Then, problem went away. I bought whole new pedal (as the old one was pretty corroded.) Tried doing the 3 depression slowly calibration, but now have no throttle response and both check and stop engine lights on. I had several faults on dash that disappeared, and now says “ no faults”. What’s going on here?
  • Draft saved Draft deleted
