ISX engine tight after overhaul
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dmj6151, Jul 12, 2016.
  1. Dmj6151
    Dmj6151 Bobtail Member
    24
    Jun 21, 2016
    The rockers were all bad, i found on the forums that this is a common problem for cummins ISX
    we did an overhaul, keeping same injectors
    when we started the engine,it was running good.
    but when pulling the trailer even empty, it runs tight.
    It feels like somethings holds on the turbo or the wheels, it does not pull like before.
    Yesterday In Oh for example, just south of Dayton claiming the big hill @ mm 40-ish, did not go better than 30 mi/h. that with a 80k lbs load.
    Is this tight something normal until breaks in? i have a 475 HP ISX , turned to 525 by dr Diesel.
    thanx for the imputs.
  3. Heavyd
    Heavyd Road Train Member
    7,399
    5,713
    Feb 4, 2009
    No, something is wrong. Sounds like it isn't making any boost, but this can be caused by anything at this point. Better have it looked at.
  4. Dmj6151
    24
    Jun 21, 2016
    turbo is working hard, i hear it, also smoking black.
    mechanic will look on it tomorrow, he suggested that since he can tell that the head was replaced before, we may have wrong camshaft part given by Cummins dealer. Does that make sense?
    any suggestion, like gear axles timing maybe?
    Thank you much
  5. magoo68
    magoo68 Road Train Member
    3,395
    5,370
    Jun 11, 2011
    st malo mb canada
    Or simply they reprogrammed with a factory spec program in order to offer warranty ..
  6. Dmj6151
    24
    Jun 21, 2016
    they didn't touch the brain at all. I have special stuff installed, i.e. work, hp, speed stuff.
  7. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    did he find anything and i would guess that the wrong timing shim was used on one or both cams
  8. kwcam
    kwcam Light Load Member
    173
    128
    Dec 29, 2012
    at the shop
    Did they remember to put that threaded plug in the head? sits between the ecm and intake, hard to see as it sits vertical, should feel air puffing out when at idle if its missing. have seen this left out a few times by others.
  9. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    check engine light on? black smoke means you either have a lack of boost pressure, or an abundance of fuel in a cylinder
  • Draft saved Draft deleted
