Just need ' Ball Park ' estimates for Following accessories.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Miami Trucker, Apr 16, 2014.
  1. Miami Trucker
    Miami Trucker Light Load Member
    142
    28
    Jul 4, 2008
    Miami,Fl.
    Hey Guys( and Gals ),I'm going to Buy a Used Truck at the end of the Year,and would like to ad the following.
    Just wanted to know what I'm Looking at with Parts & Labor,and the Item in Question.
    A New Turbo for either a Cummins,or Detroit.
    A Tri-Pac New,and Used. ( Is a used one just as reliable as a New one ? ).
    A New Reliable 2000+ Watt Power Inverter. ( Which Brand ? ).
    A New Reliable Refigerator.
    If someone knows where I can Buy ALL these Items in Florida ?....Input is appreciated.
    Be Safe out there,and Keep on Truckin '.
  3. NRG
    NRG Light Load Member
    166
    46
    May 21, 2010
    Lloydminster AB
    Cummins/Holset turbo is $4K average with the labor. There are chipper alternatives, but not Holset. Not sure for Detroit, I heard it's cheaper then the Cummins one.
    The new TK Tripac is around $11K installed, a little more if you'll opt for the arctic package, stainless steel covers or extended warranty. Used are around $5-6K.
    2000+ plus watts basic inverter runs around $250-300, you will need heavy gauge cables which are around $100-150. If you want premium stuff like Xantrex inverter or inverter/charger, those can cost between $500 to $800, depends on the model.
    Can't help on the fridge, as all my trucks had one built in.
  4. 25(2)+2
    18,504
    39,528
    Sep 18, 2006
    the road less travelled
    The Tri-pac comes with a 1700 watt inverter, at least all of the ones we used did. I'd recommend new, unless you found one with lower hours and fairly new that hadn't been in a wreck.
    The inverter has the Thermo-king brand on it but is made by one of the premium manufacturers from what I was told, possibly Xantrex.
  5. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,536
    Nov 12, 2008
    Springfield, Ohio
    Thermo King in Joplin Missouri selling used apus for 2500 when I was there in march.
  6. tinys trucking
    tinys trucking Bobtail Member
    35
    7
    Feb 20, 2014
    fridge can go up to 1500 installed by the dealer if the truck wasn't set up for it.
  7. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    836
    593
    Nov 11, 2010
    Wyoming
  • Draft saved Draft deleted
